Windows installation detects the SSD but freezes up during partition screen
SOURCE: problem in installing new operating system on lenovo T61
I ran into the same problem when installing Windows XP SP2. This is what you do.. 1. Go into the BIOS (F1 during startup). 2. Go to the SATA menu. 3. Change the setting to compatiablty. You should be able to install the operation now. After the installtion of the base os, you should go to lenovo website to download the drivers and follow the instructions there.
SOURCE: I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
SOURCE: speakers not detected by windows 7
Check whether the Audio drivers were installed in the device manager.If not download the audio drivers from HP site and install .
Good Luck
Siju.D
SOURCE: akoya medion p6622 with windows
try using the windows 32 bit ... if 64 is there it may not search your drives
SOURCE: webcam was not detected during
~To download the manufacturers and
therefore
the correct
drivers or specific software; Always get your drivers
from the manufacturer of your Laptop, Notebook or Desktop. If you were to log on to the
manufacturer's
web
site,
usually one is able to download if available, by model
number,
All available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing. This is the best way of ensuring up to
date drivers for your system and they are free of charge! I hope this helps.
