Question about Whirlpool GEW9250 Electric Dryer
The controled locked light is on and won let us do anything..What does that mean? Can it be fixed?
  • aberman3 Dec 12, 2008
    dryer lock light is on and it wont allow me to do anything either..
  • 113 Answers
Very simple. There is a button an the panel that says Control Lock on it. Press and hold it in for 5 - 10 seconds. It should unlock. thanks Dave www.washermd.com
Posted on Dec 16, 2008
It won't work with the "Control Locked" light on
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
2003 Lincoln ls v-8 cruise control won't engage. Light won't come on or anything when I hit the button. Everything else work fine.
My 2001 Lincoln ls cruise control will not work. Put in a new clockspring and that did not fix it. radio controls and horn work but the air bag light stays on continually after starting. The lights on the cruise side will go on an off -I have bought that part to replace but don't want to put on if that is not the problem.
Sep 12, 2012 | 2003 Lincoln LS
I am driving a 2005 Dodge Caravan and the Abs light has come on. What doe sit mean and what should I do?
It means there is a fault somewhere in your abs system. While the light is on you will not have anti lock brakes. It just means you will resort to the old style of brakes before abs. It will not harm anything .but is something i would have checked out.
Aug 26, 2011 | Dodge Caravan Cars & Trucks
My 2001 mercedes ms320 the gear shift is locked and i cant figure out what to do to fix it is there anything i can do
first get in to the car close the doors and shutters switch off radio and a/c then witch on ignition, when you press the brake can you hear clicking sound in shift liver, release brake and do press it again and listen, if you can clearly hear click sound, it's mean brake light switch is OK. could be faulty safety release lock in shift liver control,
Nov 13, 2010 | Mercedes-Benz ML320 Cars & Trucks
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Try to start light flashing ld and f what does it mean
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool GEW9250 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
