Question about HP LaserJet 1020 Printer
Toner splatter and faint double image
Gray streaks top to bottom in the middle of the page. Toner splatters and printing that is at the top of the page appears faintly in the middle. Printer is an HP 1020.
  • Anonymous Feb 09, 2009
    I just replaced mine and still have the problem.
  • Anonymous Feb 15, 2009
    I tried cleaning the roller and it is still printing with grey streaks and reprinting texts. with each print it gets worse.If I print a blank doc, it comes out with lots of grey streaks.
  • 479 Answers
Replace the toner cartridge or get the cartridge refilled as its about to empty .
Posted on Dec 10, 2008
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
My Brother HL 4040cn printer is leaking toner, black and yellow. It leaves spatter spots of these colors on printed pages. The machine does not have any messages. Do you know what this may be from or how...
If you've taken the printer apart and cleaned the belt unit and everywhere else in the paper's path, then it is probably either a bad toner cartridge or the drum. Since it's multiple colors producing splatter, its most likely the drum unit. Try taking the drum out and removing all of the toner cartridges and then clean the drums and corona wires. If its still producing splatter afterward, you've got yourself a bad drum.
Jul 20, 2011 | Office Equipment & Supplies
Ink splatters from new toner
Clean the drum unit cartridge and the charge roller unit.
Apr 15, 2010 | Minolta DI2510 Black and White Copier
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Jul 30, 2009 | HP LaserJet 2820 Printer
Gray continuous streaks on lower half of copy using Canon IR 1600
I assume you had the issue before you changed the toner, If so the problem is either the fuser or the Laser.
Do this:
start a print job and after you hear the paper feed into the machine open the top cover to stop the machine. You want to stop the page before it gets to the fuser. May take a couple tries.
remove the toner cart.
the page should be under the cart with the image on it.
If the line is on the page the problem is image development(toner or laser).
If no lines the problem is likely the fusing assm.
May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
Printer shows no errors
Is that problem just for that color black? sounds like you might have a bad image unit or developer. You can start out by switching the image units.. switch the Cyan image unit to the Black and the Black back to the Cyan. Print out a solid color page on the trouble shooting menu. If the Cyan prints out bad you have a bad image unit . If Black still comes out splattered then it might be the developer. We always call this company called for support and parts instead of xerox. They have good techninicians. Almost all my answer have come from here. well good luck
Nov 06, 2008 | Xerox Phaser 7750DN Laser Printer
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
HP LaserJet 1020 Printer Logo
471 people viewed this question
Ben Johnson
