Question about Samsung SyncMaster 720N Monitor
My controle panel keeps poping un on screen and i cant stop it
Press first time to turn on adjustment panel, and press next time and keep your finger fixed on button. Bad solution but works :)
Posted on Jan 21, 2009
Why does menu keeps poping up non-stop when watching tv but when sky box is paused this does not happen, why????
Can you use a digital camera to view your remote to see if it is sending out signals when it should not? It might have dirty buttons from food or other dirt. This can cause it to send signals even when the buttons are not being pressed.
May 11, 2014 | AOC Televison & Video
The setup menu keeps flashing on the screen and I cant' get it to stop also the remote control is not working
Reset your TV. Unplug it from AC mains, and pulg it back after 5 minutes of so. This must make it a hard reset. If this do not help you, contact the service center.
Jun 14, 2012 | Sylvania LC420SS8 LCD TV
I cant get thogh the phone...my security shield expiered how do i dedite it from my computer i cant pay to update it,, so it keeps poping up to updare it how do i get it off i have AVG..please help me...
Assuming you have Windows...
Click on START
Then SETTINGS
Then CONTROL PANEL
Then ADD REMOVE PROGRAMS
Find the security shield program that you want to remove in the list and click on REMOVE.
Just say yes when it asks you if you want to fully remove the program.
Good luck and please comment back if this was helpful.
Feb 04, 2011 | Computers & Internet
Menu keep on & off the screen blocking the view of the screen.
THis is an indication of faulty keyboard on the front of the set. this cuircit board can be replaced. If this is the problem you can remove this small cuicit board and use the remote until you can replace it. also this will confirm the problem. to remove this board you have to remove the bottom front panel then remove the center panel. if you remove this curict board then the menu stops poping up then this indicates the problem if not it will be on the small signal board
Oct 14, 2010 | RCA HD52W59 HDTV Projection Television
I have a dimension 2400 just reformatted to factory settings everything working fine, internet through ethernet cable, but problem with speedtouch 121g usb adapter, it just will not have it. the comp keeps...
We need the BSOD error for a better diagnostic but it appears that the soft for the Alcatel Speedtouch is at fault here - as usual; find the latest driver and use it.
How to stop the autostart: Start -> Control Panel -> System -> Advanced -> Startup and Recovery ->  Settings... -> System Failure un-check "Automatically restart"
Jun 13, 2010 | Dell Dimension 2400 PC Desktop
Favorit
You have adware on your computer. It's very annoying and sometimes hard to get rid of. I recommend Malwarbytes for quick removals, www.malwarbytes.org.
Download it, update it, and run it. Also, while you're at it, remove any programs that aren't necessary or may have been one-time-use items in the past. Go to your Start button and then Control Panel. Once there go into add/remove programs and clear it out. Typically, removing any kind of browser addons can boost your system's performance.
good luck.
Jul 27, 2009 | Toshiba Satellite A135-S2276 Notebook
Screen saver keeps poping up if i stop typing and i have 2 keep unlocking screen everytime i get back on computer and also slide show comes up when its sitting 4 awhile
xp:
1. right click on unused space on your desktop and click properties to bring the display properties, (you can also go into start>control panel and double click on display)
2.then go to the screen saver tab and click on it
3. modify the time for screen saver to come up and uncheck the box that says "on resume password protect" so you're not asked for a password everytime your screen saver is on and you're returning to work on your computer.
vista:
it's a bit different than xp but similiar in some sense..
when you right click on the desktop go to "Personalize" to bring the display properties and then go to screen saver and modify the wait time and password protected settings.
hope that helps!!
post back if you have any problems
Dec 13, 2008 | Gateway Computers & Internet
OSD keeps poping up on the screen
Replaced the control panel micro switchs.
Nov 21, 2008 | HP vs15 15"LCD Flat Panel Monitor
Removing Roxio media manager
You can try to download revouninstaller or ccleaner, to uninstall the programs.
Oct 15, 2008 | Dell Inspiron 1300 Notebook
Phantom 'd' key
ok try this gently pry off the d key and look and see if there is any junk aor anything that will make it not work properly and make sure to clean the whole area arond it and in it and then put the key back and go and press the key about a dozenb times and see if it resoponds correctly ok please keep me posted on this ok best regards mike
Aug 23, 2008 | Acer TravelMate 2300 Notebook
Samsung SyncMaster 720N Monitor Logo
252 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
