Question about Sony CDP-CX450 400-Disc CD Changer
Changer tries to load disc one when empty
1. when no CD is in the changer is starts at disk 1 and searches for a disk on all random number consecutively. 1,3,5,7,9, etc instead of displying "No Disc" 2. If a disk is loaded in slot 1 it will play it and appears to be working normally. 3. when a few disks are loaded and slot 1 is empty is does the odd number search. I think it is probably the Disc sensor. any ideas?
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Posted on Mar 07, 2009
doron_c21
  • 387 Answers
SOURCE: my cd changer wont play,
from your description it could be the laser unit
try to clean with a clean disc
if it will not help it might be the laser unit
Posted on Nov 04, 2010
walesarumi
  • 6993 Answers
SOURCE: Sony MegaStorage CDP-CX355 300-Disc CD Changer
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is refusing to play any more CD....
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens. You can add very little liquid to the cotton board like mentholated spirit and dry the lens with another cotton board that has not liquid on it.
If non of the above solves the problem, then it means the lens is weak beyond cleaning. Know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all CD's again without any problems.
I hope you understand the above.
Regards.
Posted on Jun 15, 2011
Cds will not play in loop. plays one cd and shuts off will not move to the next cd
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
    avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 24, 2012 | LG LHT874 Theater System
Cd changer cannot read cd
Its laser pickup assembly might be faulty. Click here to know more about how to clean it. Do it once, and if it do not help you, replace it with same type and number.
Sep 03, 2012 | Audio Players & Recorders
The ramdon and all play is not working. It will play one disc and then stop. It will not play in random order. I must need a new unit.
There are a number of possible reasons for this. First a little more info is needed:
1) Do all CDs play OK, just not randomly?
2) Are there any other symptoms( for example, a CD not playing all the way through)?
3) Did this just start one day or has this happened off and on over a period of time until the problem remains consistant?
Thanks,
Dan
Jan 03, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
CHM-S630 6-Disc CD Changer: what is the best 6 disk cd player to connect to an...
hi how are you , my cd changer s630 recently just started to eject the whole cartreidge i push it back and its makes some nosies and then the same ejects it
May 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
Cd won't go in the changer.
you might want to try replacing the cd magazine. and if that doesnt work it's going to come down to you replacing the cd changer itself
Feb 16, 2010 | Car Audio & Video
I have a 2005 Malibu with a 6 disc cd changer, I know the changer has 5 of the 6 disc inside it. A while back it started clicking. I removed the fuse and left it out because there was a smell like and I...
There may, or, may not be a small pinhole in the front panel of the changer. If it does have this hole, take a paper clip and insert it straight into the hole and this will enable manual ejection of the disk tray. If the hole is not there than the housing has to be removed to gain acess to the disks. Thank you, Dana
Feb 14, 2010 | 2005 Chevrolet Malibu
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
ALPINE CVA 1003 AND A DHA 5680 DVD/CD CHANGER
you have the amp remote wire hooked to the power antenna lead instead of the amp wire on the deck otherwise just hook it to a switched +12 volt source. You sure you got a DVD changer instead of just a cd changer
Mar 02, 2009 | Alpine CVA-1003 Car Video Player
Jensen car stereo
just turn the changer on, make sure it is playing a disk, (and you know whats playing) the press the scan function on your radio til it picks up that signal and lock it in.
Nov 05, 2007 | Jensen XCH6RF 6-Disc CD Changer
Remote
this is a chinese product, luck-a-lot, try searching with "autosound","audioextreme","xtremesound", a few years ago, i've found the homepage,but not today.
Apr 25, 2007 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Sony CDP-CX450 400-Disc CD Changer Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
