Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
I have a samsung rs2555sl side by side - fridge nor freezer is getting cold. what i know: 1.cleaned coils in back with vacuum, 2. fan is blowing on (hot)compressor, but no noise is coming from compressor, 3. every few minutesthere's a clicking noise coming from the back near the compressor followed by a very low hum?, as if it's supposed to start something(i don't know) . freezer temp on front of door has been 70 F for the past hour. don't know if cleaning the coils were the issue...
See http://www.fixya.com/support/t1191678-samsung_rs2555sl_not_cooling_compressor
Posted on Dec 16, 2008
In the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge. if you are in london and do not wish to open your appliance, send me an email and i can arrange a time to fix this problem.
Posted on Dec 10, 2008
I have whirlpoll side by side model gd25dfxfh182 and it stopped getting cold enough so i cleaned the coil that was extremly dirty thinking that might help it took good 8 hours to get fridge side down to 38...
IS THE FANS WORKING? DEFROST IT GOOD WITH A FAN BLOWING IN THE FREEZER SIDE FOR A HOUR, IF YOU SEE A BUNCH OF WATER ON FREEZER SIDE BOTTOM , YOU KNOW IT WAS THE PROB. LISTEN CLOSE FOR FAN WHEN YOU OPEN FRIDGE SIDE DOOR.. #2 DEFROST TIMER
May 25, 2010 | Whirlpool GS6NBEXR Side by Side...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Freezer & fridge not cooling
Your evaporater fan should only be running when your compressor runs. if the fan is bad then it would indeed make the frig not too cold because it is not blowing air over the coils to remove the heat ,so it may need to be replaced. Also check coils to see if they need a good cleaning with a vacuum cleaner. Hope this helps
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Jul 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridge and freezer not cold and frozen up
Can you remove the back panel inside the freezer and defrost the coils. Use a shop vac with the hose in the blow position instead of the vacuum position. And blow on the coils to defrost quickly. Hair dryers work also but prolonged use will burn up hair dryers. Now turn back on and see if the inside the freezer fan works. It should be running to keep the coils from freezing up. Also could be defrost timer. But this will be enough to get you going. Let me know how it goes. ken
Jan 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side.
Sep 25, 2007 | Samsung RS2534 Side by Side Refrigerator
Indesit Fridge Freezer
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing (by compressor), Check recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
Sep 08, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
230 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
