Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
My maxtor wont work at all
I plug it into the usb and the computer will show that there is new hardware put but the Maxtor does not show at all i also went into my computer and went too disk Management it does'nt show there at all what do you think the Problem could be!
  • Anonymous Dec 27, 2008
    power to maxtor ,software loaded,when at maxtor home screen red letters state "no maxtor one touch found" I have reloaded software,no change. need help.
    Problem Solver:
  • 16 Answers
It could be a couple things - do you still have the Maxtor software installed on the PC? If not you may need to reinstall the software because it may be a password protection issue.
If that is not the case the drive could be damaged. If damaged you may or may not be able to recover the data. Try downloading a product I have used before from Easeus ( Its drive recovery software and may locate the drive when Windows cannot.
If that does not work you may need a professional to repair the drive or recover the data.
Posted on Dec 09, 2008
My Maxtor One Touch 3 (300gb) external hard drive is not being recognized by my computer (or my laptop). I plug it in to the back usb port, turn the Maxtor on, then the light turns on, but the computer is...
Hi Jane,
If you are using Windows as an operation system, you can try to install the HDD manually
Click on the Start button
Right click on My Computer
click on properties at the bottom
look for the Hardware tab and click on it
look for the Device Manager button and click
look for Action in the top menu
then scan for new hardware
If this does not work, look on the Device Manager screen and you will see + Disk Drives
click on the + and it will list the drives that it sees
if you see the external HDD uninstall it and reboot
Hope this helps
Dec 22, 2010 | Computers & Internet
Maxtor 320 GB mini not working
If it shows up as a USB mass storage device it:-
1. Has power
2. It is connected to the computer via USB.
3.The correct software has been loaded for the hard drive.
The beep sound is probably an error message saying that the drive is not responding properly inside the case.
Hard drives Drives have been known to stick or not start up due to power cables or ribbon cables being dislodged. Try pushing these back into place.
If this is not the problem go to the Maxtor site ( and report the problem with the drive, not the USB which appears to functioning correctly.
Mar 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
My Maxtor Hd Wont show up anywhere in my laptop when i plug it in
it should still detect even though your using vista does your bios setting have usb2 enabled?? otherwise try a different usb port
Jun 17, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor 3100 installation
It's Plug N Play. XP will see it (Found new hardware), and will install the drivers for you and assign it a drive letter and you will see it in MY Computer. However, there may be some other features and drive options you might like on the disk.
I have anexternal USB harddrive myself and am planning on gettng another very soon.
Mar 08, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
My Maxtor mini III Want work at all
If you are running PC, go to Start -> Run -> type 'Services' (or go to Control Panel -> Administrative Tools -> then Services).
Finally scroll down to where it says Universal Plug and Play Device Host, and double click it. At the bottom, you'll see either an option to start or stop the device. If stopped, start it, and change it to automatic.
If that doesn't work, try using it with another comp. Does it open then? IF so, its your computer that is the problem here. If not, you have hardware failure.
Was there a reason why you got new anti-virus software. Did you have a virus before. If so, there might have been something that happened to it via a virus.
If this is the case, if you at least get it running some how, run a virus scan on the drive.
Do you have a warranty on the drive? Cause if worse comes to worse, you can just replace it.
Dec 09, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Transfering data from Maxtor to a new computer
It's a USB Hard drive, so you should plug the USB port into one computer, put your information on it, then plug the USB port into the other computer. Browse the Hard Drive for your data. It's like a larger flash drive.
Feb 10, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
62 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
