Question about Whirlpool Washing Machines
The Whirlpool top load washer will not spin and is not plugged.
Need to know how to replace the coupling between the motor and transmission. How to remove the back of washer. Mod. # LSQ7533JQ0
  • 370 Answers
To do this hob you dont take apart the back. You take the 2 screws out the corners of the control panel. Then it will pull forward and flip backward. Then you remove the 2 brass clips holding on the case and the whole case comes off the washing machine.
Posted on Dec 09, 2008
Will not spin. whirlpool washer model no GSQ9344EZ0
tip washer over and check the rubber coupling from motor to transmission. if the coupling breaks it will wash but not spin. it is between motor and transmission.
Jan 11, 2010 | Maytag PAV2300 Top Load Washer
Whirlpool top load washer does not spin. Does
Hi, the likely problem here is a bad coupling. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like:
8fbd130.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling.
If you have any other questions please feel free to comment. Mike
Dec 26, 2009 | Whirlpool Washing Machines
Top loading whirlpool model lsq9549pw2 will not spin
This is commonly caused by a broken motor coupling. If the washer fills and drains, but will not agitate or spin, the motor coupling is likely the cause. The coupling takes the place of a drive belt and couples the drive motor to the gearcase (transmission). This configuration is known as "direct-drive". The coupling can wear out due to normal wear and tear and easy to replace. The following link explains how:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
This is a very inexpensive repair and its not difficult if you follow the steps provided. The newer replacement couplers are more resilient and resist breaking much better. The part number is included in the link I provided. You can purchase a replacement at appliancepartspros.com for about $11. If you do not wish to order on line, take the part number and go to your nearest appliance parts retailer. This is a very common part that they should carry in their in-store inventory.
If you have any questions about this repair, or if you need additional assistance, plese let me know. I hope you fin dthis information helpful.
Oct 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool top loader(2003) and it fills up and drains but does not agitate or spin.
you need to replace the motor to transmission coupling located underneath the unit. This plastic coupling can be bought from any appliance parts store
Jun 06, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool > LSR5132PQ Top Load Washer
about 200 dollars but if there is a grinding noise or the machine will not spin or agitate the problem is more likely to be the motor coupling is broken between the motor and the transmission
Nov 12, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care 2 washer will not spin
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top loader model 3LS C8255EQ1
if the motor is running during the time its supposd to be agitating and the motor is running during the time its supposed to be spinning. then you need to replace the motor coupling. it connects the motor to the transmission it is broken and the is no connection anymore. the motor coupling is only about 10 bucks.
Feb 16, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De
