RCA model: r61wh76 chasis: itc222a tv will not completely power up green light on power button on tv will turn on for about 10 sec but there is no picture or sound
  • 3 more comments
  • tomtom12345 Dec 10, 2008
    Thank you very much. I think that I only seen maybe two transformers on the unit. Do you know if there are more or do you know which one this would be? I will check the transformers ASAP and let you know.
  • tomtom12345 Dec 11, 2008
    Thank you very much! I will do so and let you know the outcome.
  • Anonymous Mar 07, 2009
    do u have to discharge anything first?
  • jrp652ooo Mar 07, 2009
    will i get shocked by anything? what steps do i need to do?
  • 106 Answers
These units have a problem with bad connections on the flyback transformer.. Usually, soldering the transformer will fix this problem. Please take time to rate this response. If I can be of further assistance, let me know
Posted on Dec 09, 2008
  • tvguy171
    tvguy171 Dec 10, 2008
    With the back off the unit, look on the left side. You will see a black transformer with two red wires coming out of it. That is the flyback. Solder the connections underneath and you should be OK
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
Convergence off all 3 colors showing cannot adjust.
Replace the convergence power board the PSDF240 ITC222A convergence power board is available from www.tvcircuitboards.com under the rCA circuit boards.
Jul 29, 2011 | RCA R61WH76 61" HDTV
I have a rca 61" rear projection r61wh76. when i
That is normally caused by failed capacitors on the deflection board or also the flyback could be bad also located on the deflection board. Your board is the PSB260 deflection which is available from www.tvrepairworld.com
Jul 18, 2011 | RCA Televison & Video
3 color curved band lines on my RCA tv.
Ur convergence is dead.U must know how to do soldering to fix this problems?Must replaced 2 STK convergence ICS,and some or all it resistors too.Tries websites Tv repair World.com,Tvrepairkits.com to do the reapair it ur self.The shop will cost U $300 for parts and labors.
Mar 20, 2010 | RCA R61WH76 61" HDTV
No power no picture
power supply is bad.. also you need to check your convergance.
Aug 29, 2009 | RCA D52W23 52" HDTV CRT TV
Rca tv broke
Need the actual model number to help you as it sounds like the ITC222 or ITC222A flyback error.
May 27, 2009 | Televison & Video
Blinks three times and turn off, with remote or manual
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
http://www.riddledtv.com/repair/RCA.html
Sep 30, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link:
Feb 21, 2008 | RCA HD52W66 Projection Television
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
