Question about Mitsubishi WS-55909 55" Rear Projection Television
Mitsubishi WS55909 blinking green light
I purchased this TV and saw it working perfect. When I gently moved it home and tried to watch it all I got was a blinking green light. I have some background in electronics but now with TV's. I would like to try to do the repair myself if possible. It may need capacitors like many other posts and I would like to try it.
I need to know where the bad capacitors are and where to get new ones.
How long was it blinking. after a complete loss of power the green light will blink on power up as it is resetting itself. It says in the manual that it should take about a minute. Over the last two days I've have to reset it several time both by unplugging it and using the manual reset button and it has taken about five minutes for the blinking green light to clear.
Posted on Jan 04, 2009
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
I have the green blinking light problem on my
If the error code/blink code is 22 - its commonly a convergence failure. If its fast blinks with no set pattern its normaly a DM module problem. Both can be fixed with kits from www.TvRepairKits.com
Mar 19, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Televison & Video
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Blinking green light on front of ws55909 projection tv. have reset it by both unplugging and pushing reset button. light continues to flash. has for 2 days. can't operate tv
do this press and hold device and menu button on the front of set.. this is to retrieve a to digit error code flashed by the leds. also this set neds to "boot" let the led flash for at least 70 seconds. if it continues to blink the tv failed to boot. There is service bulliteens that states capacitors in power supply can be bad. this capacitors are kinda hard to get to and rather invovled to replace
Jan 15, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi wd52725 green blinking light
Haven't done anything as of yet. I saw many posts that stated it costs between 800 & 1500 to fix the problem with no guarantees on the repair or how long the repair would last. Still weighing my options.
Dec 29, 2008 | Mitsubishi WD-52725 52". Rear Projection...
TRY TO GET TO THE MENU, SETUP, AND EDIT YOUR SETUP SO EVERYTHING IS DEFAULT. I TOOK A 2001 50" HOME LAST NIGHT, MY SLEEP TIMER LIGHT ON THE FRONT, BLINKED FOR A FEW MIN. THEN, YOU CAN TURN IT ON AND RESET.....HOPE IT HELPS.......????
Dec 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green light will not power up
My WS-55859, Did the same thing. Power went out, when it came back on the green light in front of TV would blink, but TV would not power on. Did some googling and saw multiple posts for "blinking Green light" or "Blinking Green light of death". Most of the posts pointed to replacing capacitors on DM Power board. I followed the direction and it worked great. Note the TV shop guy who did the soldering for me said the capacitors "looked fine" and they were not the problem. I couldn't tell the difference between a good or bad capacitor, so I asked him to swap them anyway. He did, I plugged the board back in, buttoned up the back of the TV. After 60 seconds Green light stopped and I started watching TV again... Here is the link to the best instructions I found (http://hdtvoice.com/voice/showthread.php?t=32186).
Aug 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Open Questions:
Mitsubishi 55" big screen TV powers down after 70 secs We had a power outage in the neighborhood, after which our Mitsubishi 1080 HDTV WS-55909 only had a blinking green light on the front (no variation or pattern), even after the set was powered down. Upon reading online, it appeared the DM module capacitors were the likely culprit, so I sourced (7)1000 microfarad capacitors and replaced them, then reassembled the TV. This was the first time I'd soldered on a circuit board, so of course a lot of things might have gone wrong. However, after that the TV now powers up, but I only have a blue screen and cannot get the remote to work except to power the TV on and off (tried changing batteries in remote, reprogramming remote per setup manual, etc). Further, the TV powers off after 1 min and 15-20 seconds. I then tried to see if I could get any of the attached devices to work on their own with no other devices on except the TV. Each of them yielded a blue screen (X-Box, VCR/DVD recorder, Wii, cable) except the DVD player -- which displayed a great picture! The problem is the DVD will play 1 min 15 seconds then the TV will shut down and the green light will blink steadily (no pattern) for 60 seconds, then power down. And this only works if the DVD is on before the TV is turned on, and since the remote doesn't work I have to press "play" on the DVD player. The DVD is hooked to Component Input 2 so that input appears to be working fine. The VCR/DVD recorder is attached to Component Input 1. When I had it powered up and turned on the TV, I got a blue screen. However, when I left the VCR/DVD on and then turned on the DVD, there were jagged lines on the TV for 3-5 seconds, then the TV made a popping sound and shut off. When I then turned on the TV (i.e., with both the VCR/DVD and the DVD on first), the DVD worked but could not switch to the VCR/DVD without the TV turning off. I also tried switching the cabling for the DVD to Component Input 1, but the DVD no longer worked. When I tried the VCR/DVD on Component Input 2, it still only yielded a blue screen. So is Component Input 1 bad? And why would the TV work with the DVD in Component Input 2 but not the VCR/DVD? Obviously I have multiple problems here. The first one to deal with is the TV shutting off after 1.25 minutes. I am unable to see where I can get an error code when the blinking light just blinks quickly without any pattern, and neither the front panel controls nor the remote control work. Perhaps most of my inputs on the rear of the TV don't work now except Component Input 2 but I don't know how to test this. So I made a little headway with the capacitor replacements, but not sure what I can do at this point. Any suggestions? I've seen references for other Mitsubishi big screens that shut down like this, and the fix was related to the output power module, but not sure if it applies the the WS-55909. Thanks in advance for any help you can provide. estout7
Jun 28, 2012 | Mitsubishi WS-55909 55" Rear Projection...
See all Mitsubishi WS-55909 55" Rear Projection Television Questions
Mitsubishi WS-55909 55" Rear Projection Television Logo
362 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
