Question about Toshiba Satellite 1805-S274 Notebook
Toshiba Satellite A35 Turns on and off constantly
After replacing the power jack, re-assembling and powering up, the machine cycles on and off continuously. The cooling fans turn on and off in the same way and I can hear the DVD player cycle on and off as well. The On-off switch does not allow me to power down completely and the only way to make it stop is to remove the battery. I let the battery charge fully (amber light turned to green after a few hours) hoping this was the problem. However the on-off problem persists. Help!!
  • juanderecho Dec 09, 2008
    Thank you - would you be so kind as to share with me the relationship between RAM the symptom?
    President:
  • 2,110 Answers
You have to change ur RAM first...
Posted on Dec 09, 2008
My toshiba satellite U505 turns off suddenly when i turn it on. What might be the problem
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-toshiba-satellite-u505-ac-adapter-19v-3-42a.html
Nov 22, 2012 | Toshiba Satellite U505-S2940 Notebook
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
The power jack is broken and I need to replaced it. I have one available now but looks like I need to remove the mother board from the laptop. How is that done?
with great difficulty, you may be in luck and find an online guide with video on youtube.
There is a service guide for the A30, this should help with stripping the laptop, it takes a while to load, http://tim.id.au/laptops/toshiba/satellite%20a30.pdf
Oct 05, 2010 | Toshiba Satellite A35-S159 Notebook
Where can I buy a new battry fo my labtop Toshiba A35-S1592
You can buy new batteries at the below link
http://www.laptoppartsshop.com/models/original-Battery/Toshiba-Satellite-A35-S1592
and also
http://www.amazon.com/Toshiba-Satellite-A35-S1592-Notebook-Replacement/dp/B0016WFPVA
Jul 02, 2010 | Toshiba Satellite A35-S1592 Notebook
Im Having trouble getting the back cover off a Toshiba Satellite A30 I need to get to the power prong to replace it and the cover seems to be not coming off
Here is Toshiba Satellite A35 (which is the same as A30) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, 4...
Sep 02, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Need take down instruction to fix a35 power addapter
Hello there:
if you do a google search
toshiba satelite a35 dissasembly instructions
there will be a big section on these laptops so make sure you get the right ones ok?
best regards mike
Aug 17, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba S25-A279 - dont turn on
The memory may be bad. Try changing it.
The hard disk may also cauuse such problem.
So troubleshoot harddisk, memory and any new device you recently attached.
Jun 19, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Toshiba Satellite 1805-S274 Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
