Question about Whirlpool Washing Machines
Hi I have a whirlpool AWO 10961 washer that keeps displaying the error code F06 do u have any idea what this means. Thanks Ian
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
SOURCE: whirlpool washer duet
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Posted on Nov 30, 2007
jsrock516
  • 5911 Answers
SOURCE: f06 error code on Whirlpool duet washer
An explanation of your error code can be found at the following link:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
In a nut shell, usually one of the motor windings fails, causing the Drive Motor to not rotate at the correct rpm, or not at all. Or, the Motor Control Unit fails. Both are simple repairs and can be accomplished by the average do-it-yourselfer. If you wish to attempt this repair, let me know and I can give you the steps required to complete it.
These parts can be found at searspartsdirect.com. Just type in your model number and look under the "Pump and Motor Parts" heading on the next page. The MCU will be listed as item number 1 (part #8181693). The Drive Motor is listed as item number 16 (part #8182793). You can also try repairclinic.com, pcappliancerepair.com, and partsstore.com for comparative pricing. If you require further assistance, please let me know.
Posted on Jun 28, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool awo3561 fault showing as f06? what does
"F06" is a Motor Speed error code. It means the motor is not spinning, or you have a loss of commuincations between the Motor Control Unit (MCU), Central Control Unit (CCU) or Drive Motor. The following link explains:
The easiest place to start would be to verify all your connections between the Drive Motor and MCU are intact and not corroded. Then, perform resistance checks on the Drive Motor windings.
For ease of troubleshooting, UNPLUG the washer and remove the top panel by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off. Position the washer where you have full access to the rear. Remove the back panel of washer. With the top and back removed you will have full access to the CCU, MCU and Drive Motor.
If you have questions along the way, or if you require addtional assistance, please let me know. I hope you find this information helpful.
Posted on Mar 05, 2009
richardsimpl
  • 230 Answers
SOURCE: F06 error
HI There
Here what you need on error codes.
  • Check the MCU
Hope this helps let me know. Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 11, 2009
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Error code F06. what does this mean?
Whirlpool (Kenmore) 'F06' states 'tachometer failure, no motor movement detected'.
Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 12, 2011 | Kenmore Elite 45986 Front Load Washer
I have this written in my machine F06 what is that meanning
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool AWM8143 Front Load Washer
What does the F06 error code on the Kenmore Elite HE3 washer mean?
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F06 and washer stops spinning , must keep restarting
Hi
Thanks
Rylee
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM8143 sixth sense
Try replacing the brushes this may solve the problem
Jul 03, 2008 | Whirlpool AWM8143 Front Load Washer
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
