Question about Hotpoint Aquarius WF000 Front Load Washer
WASHING MACHINE DRUM WILL NOT TURN
AFTER INVESTIGATION THE BELT HAD COME OFF THE DRUM.
AFTER FITTING AND TURNING DRUM BY HAND THE BELT IS FORCED OFF OF THE SIDE OF THE DRUM PULLY.
THE MOTOR PULLY APPEARS TO BE MISALIGNED WITH THE DRUM PULLY IS THERE ANY ADJUSTMENT I CAN CARRY OUT.
  • Hotpoint Master
  • 3,463 Answers
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
How do you replace the belt on an indesit moon washing machine? I have managed to take off the belt fromt he motor and the drum, but trying to get the replacement band back on it very hard - if it just...
Most belts for washing machines are of the stretch type and they will take a lot of force to get on.Try to put on motor pulley first the try on drum pulley one side or other whichever feels easiest as you start it on pulley start turning drum pulley whilst holding the belt to stop it slipping,keep turning until it goes on then line up to centre of drum pulley.
Hope thet helps.
May 09, 2010 | Washing Machines
Tip
Error Code & in washing machines..
Error 7 means - “Motor jammed / Drum shaft jammed / Tacho generator fault”
Motor jammed
The first possible fault could be if the motor is trying to turn but the motor is physically jammed. This is likely to be rare. It’s easily tested by opening the door on the washing machine and spinning the drum by hand. If it moves normally and freely it’s clearly not jammed and this is not the fault.
If it is jammed or very stiff then making sure the machine is disconnected from the mains supply you can just take off the drive belt. You can then see if the motor is jammed or not because the shaft where the belt fits wouldn’t be able to be turned by hand.
Drum shaft jammed
This would cause the exact same problem in that the motor is trying to turn but because the drum was jammed it couldn’t. Again, easily tested by turning the drum by hand – if it’s free then it isn’t the fault. If it’s jammed or very stiff, removing the belt will let you determine whether it’s the motor or the drum that’s jammed.
The way a washing machine detects the speed of the motor is via the tacho coil which is the last potential fault listed.
The tacho coil is on the outside of the motor attached to the end opposite the drive belt with 2 thin wires running from it. It’s a small coil that surrounds the shaft of the main armature where a small round magnet is attached. As the armature turns the magnet on the end of the shaft turns inside the coil. It’s then easy for the pcb to count each revolution of the small magnet and work out how many revolutions per minute it is turning.
on Mar 17, 2010 | Washing Machines
Can't fit a belt to the Bosch washing machine. Is
There is no provision made for adjusting belt.
With the rear panel removed, fit the belt round the motor pulley first, and slowly feed it round the drum pulley, at the same time turning the pulley by hand..
Watch your fingers, it will be tight.
You will find it easier to do if you lean the washer away from you, this will give you more room to get your hands in..
Hope this helps you.
Dec 03, 2009 | Bosch Washing Machines
Turns on and makes noise but drum dosent move what is wrong . the drum wont move to wash or anything.
Check that the drum is free to move - by rotaiing it by hand. If it rotates very freely - it is likely you need a new drive belt. If the drum is very stiff - and won't move, it is possibly a faulty rear bearing. If both these checks are not the problem, it could be a motor or control board fault. It can be a cheap set of brushes needed for the motor - or a new control board.
It really needs investigation to identify which part is needed before replaements are ordered.
Turn off and unplug before investigating further.
Sep 30, 2009 | Washing Machines
How to attache drive belt to drive drum .belt will not reach.loosening bolts that hold motor on did not help.forced on but belt twisted on drum.
Remove rear cover of washer, and top cover also, tilt washer towards you, get someone to hold washer steady, fit belt round motor pulley,and slowly feed belt round drum pulley, watch your fingers, keep feeding belt round oulley, turning drum at same time, it will be tight, but persist, and belt will go on.
Please rate my solution.
Thanks.
Sep 28, 2009 | Hotpoint Aquarius WF220 Front Load Washer
HOW DO I FIT NEW BELT TO HOTPOINT WF430 WASHING MACHINE
The easyest way to fit these belts is to locate it on the motor pulley and as far onto the right hand side of the main pulley (viewed from the front of the machine) as possible. Hold it on the main pulley with a cable tie and rotate the drum anti clockwise by turning it from inside. The belt will be drawn onto the pulley and the cable tie will snap as it rotates. (Easy)
Jun 17, 2009 | Hotpoint WF430 Front Load Washer
Cant get new drive belt to fit washing machine. right one but cant get it to stretch enough to fit from drum wheel to motor
this is a common problem as nowadays stretchy belts are used in order to avoid motor adjustment.
fitting requires some brute force. the way i do it is to put the belt on the motor pulley then start it as much as i can on the drum pulley. turn the drum pulley keeping force sideways to push the belt on and as you turn, the belt will go on
Oct 21, 2008 | Hoover Washing Machines
F1245w
I have always fitted the the motor cog first then start by placing belt on half of the drum cog as much as you can, then by hand turn the drum and the belt should slip on.
lee
Jun 11, 2008 | Zanussi F1245W Front Load Washer
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
388 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
