Question about Gigabyte GA-8IE533 Motherboard
My daughter has an emachines W2888.It quit working so I put in a new power supply.It still does not work.When you plug it in you see a light come on the mother board but nothing else .What else could this be?
  • Anonymous Jan 22, 2009
    same prob
    President:
  • 2,110 Answers
Try to change RAM..
Posted on Dec 09, 2008
My emachine T2958 will not turn on but it did work for about 3 weeks and one day it just quit working. I opened it up and plugged it in and a green light came on and is making a buzzing noise. Is it the...
It sounds like a power supply failure. Do you plug it straight into the walll or into a surge protector. If you are close to a best buy, go to geek squad they will diagnose the issue for free but the fix is real simple. Let's just put it this way there are a few things that protect the motherboard from getting fried. If it is the PSU u are looking at roughly 40-60 dollars and it is a matter of 6 connections. Give me a shout if you need more help
Jan 29, 2010 | E-Machines eMachines T3830 PC Desktop
W2686 power supply problem?
Yes, any power supply will do as long as it fits in the case.
Either a regular power supply
or
a Micro power supply
They can be purchased online from Tigerdirect in any number of wattages.
Jun 14, 2009 | E-Machines eMachines W2686 PC Desktop
W2888 emachine just shut down as if it were unpluged
THE LITTLE LIGHT ON THE MOTHERBOARD SHOULD ALWAY BE ON. THE FAN ON THE POWER SUPPLY RUNNING NORMAL OR FAST.
DID YOU ADD ANY NEW DEVICES TO YOUR COMPUTER LIKE UPGRADING THE RAM, VIDEO CARD, NEW INPUT DEVICE.
NEED MORE INFORMATION.
ROD
May 12, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
Emachines W2888 not turning on
Easy fix! Sounds like you bought a bad Power supply. Purchase an identical p.supply and it will run like a car!
Jan 27, 2009 | E-Machines eMachines Desktop PC
Emachines W2888 will Not Start up
Most likely the system board has failed. If the power supply had blown it is not unusual for the subsequent spike to blow the system board. On the other hand it may have been the system board that failed and the PSU is ok. Emachine system boards are rubbish
Either way you will need a new board and most likely a reinstall of the OS
Dec 09, 2008 | E-Machines eMachines Desktop PC
Emachine not responding
Sounds like intermittent power supply. Power supply not putting out required voltages.
Apr 05, 2008 | E-Machines eMachines Desktop PC
W2646 crapped out
Some eMachines computers (like many from Dell) use a non-standard pin out for their power supplies, so if you try a standard ATX power supply it may not function.
However, in my experience it IS likely to be the motherboard. Luckly I have been able to replace quite a few of the eMachines mobos with a standard mATX mobo, since you can probably remove the IO plate. You'd certainly want to replace the power supply when doing so.
Jan 25, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
Gigabyte GA-8IE533 Motherboard Logo
71 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
