Air Purifiers Logo
nancy waterall Posted on Jul 09, 2012
Need hap8650 manual
Just changed filters and yellow light is staying on. need to get it back to green light again
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jul 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
6616
Points
56
1helpful
How do we change filters on a HAP8650 air purifier?
"After replacing the HEPA filters, RESET the Filter Life Monitor by inserting a small object (such as a pin or paper clip) into the hole below the red filter change light marked RESET and holding it down for 2-3 seconds." This came straight out of the Owner's Guide. Hope it helps!
7helpful
Red led light on constantly
electronic circuit needs replacement
5helpful
Water filter
electronic circuit needs repair
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • 0helpful
    4answers
    Red filter indicator light
    Hi Linda - there is a "reset" hole - you have to stick a pin or a paper clip in the hole when you change the HEPA filter - I just found this out myself! It does work. Mine didn't work right away, but it did end up resetting and went back to green after a few moments. I think this happened to me last time. The filters are really expensive, but you can get them at Walmart. If you need more information, email me at [email protected] and I'll tell you what model filter, etc.
    Replacement Filter
    i do apologize for the inconvenience that your having with the product. The only other thing that i can suggest cause you already did the majority of the troubleshooting, is that there should be a small pin hole on the top of the unit. that's the reset. stick a small pin in there and hold for about 3 seconds and then the unit should be reset. if that doesn't work there is something internal that is going on. recheck the manual for the trouble shooting options as well.
    Top Holmes Products Air Purifiers Experts
    ADMIN Andrew
    ADMIN Andrew
    David Kassin
    David Kassin
    Are you a Holmes Products Air Purifier Expert? Answer questions, earn points and help others
