Question about SanDisk ULTRA II 4GB Compact Flash Card Flash
Sandisk SD memory card problem
Hi there, my new memory card wont reade at all from the card reader. I think I may have accidently moved the boot up file and the disc is now empty. Any ideas how i might eb able to repair it please? Thnaks, Michelle
  • 1 more comment
  • Michelle Rowe Mar 17, 2007
    Any other ideas please?
  • Kurt M Dec 22, 2007
    Just bought Sandisk Ultra II to replace a Sandisk memory card that worked fine but was misplaced.Cannot get data to load to my computer.I am using a Sandisk reader that works fine with my wifes Sony memory stick.I bought a second Sandisk Ultra II 4 GB thinking it may have been defective but still am unable to get data to my computer.
  • munish123 Jun 21, 2008
    Hi I am using Sandisk 1 GB SD card, After taking photographs from my digicam i can see that photographs on camera, but when i try to transer those photographs on my computer by directly connecting the camera then computer shows no photograph and when connected through card reader memory card is not detected by the computer.
    please guide.
Same thing happened to me. I bought a program called search and rescue from Compusa and was able to recover all files and saved to my hard drive. Yes it does sometimes happen to memory cards. How it happened, not sure, but i recovered..good luck art
Posted on Mar 15, 2007
I cant format my memory card and my cellphone cant read it to what should i do .
Get a Multimedia card reader for yourself. Plugin in the card reader in computer and insert the SD card in it. Once you see the SD Card in My computer that means your card reader is able to read the SD card that you have inserted. You can right click on the icon and click format. Do a quick format and choose file system as FAT32.
or
You can use SD Card Formatter and can follow their manual. I think that will also work for you. http://www.sdcard.org/consumers/formatter_3/
Jun 21, 2011 | SanDisk 2GB microSD Memory Card
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Using a SanDisk Micro in a SanDisk adapter in a USB Card Reader. My system keeps reporting the card is write protected, no matter the position of the lock switch. I formatted the SD in my phone, no...
Most SD memory cards have a tiny slide switch on the edge of the card. Move this slide switch from Read to Write to turn off the write protection.
Nov 12, 2010 | SanDisk 2GB microSD Memory Card
How to format my corrupted memory card (scan disk 4GB sd)? i insert my mmc to card reader and connect to pc to format it but error " no memory card insert ". i think the computer cant read my card at...
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
Oct 02, 2010 | SanDisk 4GB microSD High Capacity Memory...
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Open a password..
I think you have a SDHC sd card have a look at the card and see if it says 2gb SDHC if it does then you need a new SD card if it doesnt have SDHC then it will be a fault with your card reader.
Feb 10, 2009 | SanDisk 2GB microSD Memory Card
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
HELP w/ Sandisk 4GB MicroSDHC Memory Card with SD Adapter
First check it in ur laptop whether Card reader was installed or not.If ur laptop doesn't install drivers then Take from nearest service center and install the drivers.
Thanks
Mar 06, 2008 | Computers & Internet
SanDisk ULTRA II 4GB Compact Flash Card Flash Logo
233 people viewed this question
Top SanDisk Cameras Experts
Henry
Nikki  Mclean
Nikki Mclean
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
