Question about De Dietrich Ovens
Main (lower oven) will not switch on
When the funtion switch is operated the circular flashing indicator which displays when over in working does not function fully. Although the fan initially gives the indication it is going to operate it does not do so.
  • De Dietrich Master
  • 3,463 Answers
You need to access the fan motor and see if you are getting a supply to it, if you are and it is not going, then replace it..
If no supply then I would suspect faulty selector switch or thermostat.
Plsz leave feedback.
Posted on Dec 10, 2008
On my model #EW30EW65GS3 in the self cleaning cycle even tho I removed all the racks & the rack supports it keeps flashing remove racks
Hello. From what you're describing, there might be a problem with the rack switch. It is connected directly to the main oven display board at connector P10 for a single oven(See pic 3, left side, middle). On the double oven model, there will be a P12 connector near the same area. TURN OFF POWER TO THE OVEN BEFORE ATTEMPTING TO CHECK ANYTHING!! On the double oven display board, there will be a connector P10 and P12 for the upper and lower oven racks.The part number for the main oven display board is 7316516536 in case the switches are good. The rack switch part number for the upper and lower oven is 7318903403. The part number is the same for the switch in the single oven model. Note the designation on the exploded parts diagram as 14(with a circle around the part). I've included the last pic(the oven relay board) just for future information.The part number for it is 7316443919(dual oven relay board). If you are hesitant about attempting to troubleshoot the oven, definitely call for service! This can be an INVOLVED REPAIR requiring advanced troubleshooting. The connectors on the circuit board can be damaged easily as they are multi-pin devices. You will need a voltage/ohm meter with fine probe tips to perform continuity checks on the rack switch(s). I hope I helped you!
Sep 26, 2015 | Ovens
Flashing
switch off the oven..remove the power cord from mains..keep power button pressed for approx 15 seconds and then plug in the power cord and try using
Apr 06, 2008 | KitchenAid KEMC378 Electric Double Oven
The display flashes F C then starts beeping. I turned off the breaker for 5 minutes and put back on but it started again.
Communication error detected by display board(main board), Lower oven relay board not powered up, check all power connections to the oven relay boards. Check all connections from the main board to the relay boards.
Aug 22, 2015 | Thermador SC272T Electric Double Oven
Replaced failed circular element in main oven. Still not working and code 555 displayed when power turned back on
Make sure you have 220 volts at the wall plug for the oven. If not try resetting the circuit breaker for it. You may need to replace the breaker if it is several years old.
Jun 22, 2015 | Ovens
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Digital display is not working
you need to check the main power and see if the power is orrect if so replace the electronic control better known as the clock timer
Jul 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F64 error
The F64 on those oven`s is indicating the onboard watchdog ( control board ) has detected the cooling fan for the lower oven isn`t being detected or isn`t funtioning.
That may or may not be the problem though. I`ve found often it is actually the "sail switch" located in the vent of the oven ( at the bottom where the unit exaust`s ) is stuck either due to grease or being damaged during installation.
You`ll likely want to call in a pro to actually determine what is in fact initiating this error code, but it is definetly related to the lower cooling fan circuit.
Let me know if I can assist you further. Thank`s for visiting "fixya" for your oven inquiries and good luck.
If you feel as though you are capable to service this on your own let me know and I`ll attempt to guide you.
macmarkus :)
Mar 25, 2010 | Thermador SC302T Electric Double Oven
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
138 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
ray gallant
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
