Question about Minolta EP1083 CS/PRO Copier
Copier only copies 90% of sheet in 100% mode
I have a Minolta EP1085 copy machine that only copies approximately 90% of any form and prints copies with a gray tint to them. Read the service manual and utilized the suggested cleaning leavers without achieving any significant difference. Can anyone Help !!!
    President:
  • Minolta Master
  • 990 Answers
You have to go to service mode to adjust it that's ,technician's job,better looking for a local service provider
Posted on Dec 09, 2008
How to rest toner from black background
If the copy is dirty background first clean the optical parts component,mirror,lamp,charge corona,transfer unit.If it is OK verify the imaging unit developer and drum,if necessary change it.
Nov 30, 2013 | Konica Minolta Genuine Di181 Di-181 Ep1085...
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Minolta cspro ep1085 need to know if there is a hard drive in this copier
No there is no hard disk drive in the EP1085. This was an analog machine and as such had to provision for PC connectability, printing or scanning. Therefor no hard drive needed or offered.
Thank You for using Fixya!
WheatlandServices
Sep 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Date 18th May 2010 Dear Sir What is the
THEY ARE BASICALLY THE SAME MACHINE THE 1085 HAS MORE FEATURES.THOSE MACHINE ARE ABOUT 10 YEARS OLD AND PARTS ARE BECOMING HARD TO GET. I WOULDNOT BUY EITHER.GET A NEW DIGITAL COPIER AND YOU WILL BE ABLE TO PRINT FAX SCAN AND COPY AND PARTS WONT BE AN ISSUE FOR MANY YEARS
May 18, 2010 | Minolta EP1083 CS/PRO Copier
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Oct 03, 2009 | Minolta EP1083 CS/PRO Copier
Machine makes a loud wheezing noise just before
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
May 02, 2009 | Minolta Office Equipment & Supplies
Photocopying a book
yes, there is a button for book form.
it will either be in additional functions or duplex mode.
when copying leave book open on glass it will scan the first page then scan the other page. you can have it on two different sheets or one double sided sheet.
Good luck.
p.s.: it should be in the user manual also if you have it.
Nov 15, 2007 | Canon imageRUNNER 5000 Copier
Problem with Konica Minolta Di1610
Incorrect T/C type means that toner cartridge have not good contact with toner chip, is good to clean this chip, or contact inside magine is not good. Change toner cartridge and if that problem remain, its needed replace contact unit on machine
Sep 21, 2007 | Konica Minolta Di1610 Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
88 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
