Question about Campbell Hausfeld 13 - Gallon Air Compressor
Hose from compressor to air tank
Where can I buy a replacemelnt hose that goes from compressor to compressed air tank?
    President:
  • Campbell Hau... Master
  • 1,388 Answers
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Posted on Dec 09, 2008
My Porter Cable pancake air compressor is getting too hot and melting my air hose
ASSUMING THIS IS AN ELECTRIC MOTOR DRIVEN SINGLE STAGE COMPRESSOR, IF THE COMPRESSOR USES OIL IN THE CRANKCASE, THE PRESSURE SWITCH SHOULD CUT OFF AT 125 PSI AS THE ACT OF COMPRESSION HEATS THE AIR QUITE HOT. THERE IS ALWAYS SOME OIL THAT PASSED THE PISTON RINGS IN THE COMPRESSED AIR. IF THE COMPRESSED AIR GETS HOT ENOUGH, THE OIL VAPOR CAN IGNITE AND THE FLAME CAN CARRY TO THE TANK FOR AN IMPRESSIVE EXPLOSION. THIS ORDINARILY DOES NOT HAPPEN BELOW 175PSI OR MORE.
OILLESS COMPRESSORS CAN BE SET TO 150 PSI. WITH EITHER TYPE OF COMPRESSOR, THE HOSE SHOULD BE ATTACHED TO THE REGULATOR OR THE REGULATOR STACK, NEVER TO THE COMPRESSOR, AS THE COMPRESSED AIR LOSES MUCH OF ITS HEAT WHILE IN THE RECEIVER. IF THE WHOLE TANK IS GETTING HOT ENOUGH TO MELT A PROPERLY ATTACHED HOSE, YOU HAVE A DANGEROUS SITUATION, CHECK THE OPERATION OF THE PRESSURE SWITCH, UNLOADER VALVE AND RELIEF VALVE. THE RELIEF VALVE SHOULD OPEN AT NO MORE THAN 150 PSI, THE UNLOADER VALVE OPENS WHEN THE PRESSURE SWITCH SHUTS THE MOTOR OFF, AND SHOULD ONLY HISS FOR A FEW SECONDS AS IT DUMPS THE PRESSURE ONLY IN THE COMPRESSOR AND THE LINE FROM THE COMPRESSOR TO THE TANK INLET CHECK VALVE. IF THE UNLOADER VALVE HISSES MORE THAN A FEW SECONDS, THE TANK INLET CHECK VALVE IS LEAKING AND NEEDS TO BE SERVICED, CLEANED OR REPLACED. IF THERE IS CARBON BUILD UP IN THE VALVE, THERE IS EXCESS OIL PASSING THE COMPRESSOR PISTON RINGS, REPLACING THEM MIGHT FIX THAT IF THE CYLINDER OR RING LANDS ON THE PISTON ARE NOT TOO TAPERED OR WORN.
Jan 25, 2016 | Porter Cable Air Tools & Compressors
Air compressor wont produce more than 60psi
clean the one way cheak valve on the head of the air compresser motor whier the big line comes out and goes to the tank.
Sep 09, 2012 | Coleman Powermate 27 Gallon Air Compressor
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I noticed the steel braided hose which is the intake for the air supply is very hot to the touch. Like extremely hot and was just wondering if this was normal? I removed the air filter and tried running...
I believe the hose you are referring to is the "Aftercooler" that connects from the head (outlet) of the compressor head to the air tank. Under normal use, the aftercooler will get very hot. Air is heated when compressed and will heat up this hose and the inlet area of the tank.
Oct 15, 2017 | Dewalt D55270 gas powered air compressors
My regulator adjustment knob is not working and there is no air pressure on the psi regulator gauge. Air goes into the tank and the hose from the motor to the tank gets extremely hot. Is this normal for...
The air discharge hose will normally get very hot. When the pressure regulator valve fails, it may no longer give you air. As a temp measure you can get air out of the unit by removing the safety pop valve and installing a tee fitting in the port. On one side of t fitting reinstall safety. On the second port install a quick connect for full tank pressure. Make sure that there is not air in the tank by pulling on the ring of the safety before you take it off. Replacement parts are at www.toolpartsdirect.com or dewalt service center. Good luck
Jul 12, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Compressor will only hold 20 lbs and looking for some troubleshooting ideas
First check for obvious air leaks:
1. The drain valve on the bottom of the tank.
2. The air hose, both end connectors and the length of the air hose.
3. The air pump, where the line comes out of the pump and where it goes into the tank.
A spray bottle with soapy water works well for this. Sprayed on these areas, look for bubbles indicating a leak. If the motor/air pump is hot make sure the bubbles are not from the solution boiling away.
If these check out, you may have a damaged valve plate or piston/cylinder assenbly. Damage to either will not let the pump move enough air to fill your tank. To check these you have to remove the pump head. The check valve(s) are on a plate directly under the head. Check that the reed(s) are not chipped, cracked or broken off. They have to be in perfect condition to seal the incoming and outgoing air holes so air can be compressed enough to fill the tank. If OK, check the piston and cylinder. They have to be in very good condition to compress the air also. Some times the ring(s) around the piston get damaged and won't seal to the cylinder well. If any of these are damaged you'll have to replace them to get a good seal so air can be compressed and forced into the tank.
Jun 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
My compresser build pressure, stopes,then it leakes the air from the electrical box buy the small line comes from the tank to the othank youff/on switch box, goes down to 80 lbs then start again ?
G'day. You have a leaking check valve.This is the valve that is inserted between the compressor pump discharge pipe & the tank.DO NOT try to remove this valve with pressure in the tank.DRAIN ALL AIR FIRST. Some rightangle check valves have a removable hex nut with a valve behind which can be replaced seperatly(in stead of a new check valve assembly). Just to clarify-the check valve is at the tank end of the little hose that the air is leaking from. WARNING-DO NOT REMOVE ANY FITTINGS WITH AIR IN TANK .Hope this was helpfull
Regards Andrew Porrelli
May 11, 2011 | Porter Cable 4 5 Gallons 150PSI Job Boss...
The compressor has air in the tank but the needle shows 90psi the regulated preasure needle does not go to 20 and there is no air comming out of the hose
you would have to go to the store where you bought it from and buy a new pressure regulator. i've had this happen on a similar compressor. valve inside pressure regulator goes bad from moisture in tank if its not drained daily after each use and starts to corrode. if i can help any other way let me know and good luck
Jan 19, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a Hitachi EC12 Portable Electric 2hp Air Compressor. It builds air pressure fine and shuts off normial. But if I attach a blow nozzle or another attachment to the hose and try and use it, the...
This is a stab in the dark.....but have you emptied the condensation out of the tank? It may reach max pressure....but have little air compressed inside the tanks. Just a guess.
Dec 13, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Coleman 5Hp Compresser
All electric compressors share a basic design with ac power pressure switch with unloader and checkvalve between the pump and the tank. When the pressure switch powers off, it unloads the compressor by releasing the air in the discharge hose. You will notice a small tire stem pin and a lever to engage it somewhere on the pressure switch. If the compressor stops before reaching set cutoff point, the air pressure remains in the discharge hose not allowing the motor to start, thus the hum you hear. Solution is to check for the proper function of pressure switch /unloader, tank check valve (if check valve leaks air back to compressor it will load motor causing hum) and extra measure check capacitor for at least 90% of rated valve. Finally, do not run this compressor with an extension cord, use more hose instead. enjoy
Oct 22, 2008 | Coleman CP0302013 20 - Gallon Portable...
Campbell Hausfeld 13 - Gallon  Air Compressor Logo
243 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
