Question about Sony KP-61HS10 61" Rear Projection Television
1080i flashes for 3 seconds at every transition of scenes
I want to disconnect the 1080i 3 second flash. its disruptive to the continity of a show
  • 4 more comments
  • gjg0 Dec 09, 2008
    The display button "off" does not stop the 3sec flash of 1080i. I don't believe the answer is that simple.
  • gjg0 Dec 09, 2008
    Its not a power on power off situation. THE 1081i DISPLAY FLASHES ON ALMOST EVERY SCREEN CHANGE>
  • gjg0 Dec 09, 2008
    The digital tv format being rec'd ,ie 1080i;is displayed on the screen for 3 seconds at every screen change or fast action sequence and is not simply random.
  • gjg0 Dec 09, 2008
    Not a malfunction, page 27 of the manual provides for this function.
  • gjg0 Dec 09, 2008
    Again the display button is not the answer.
  • gjg0 Dec 09, 2008
    Thank you this solution was the answer.Sony nearly craped when I told them about the service billetin. If they don't pay for it I'll sue them, it will be fun. Thank you Crazyeetrayn for all the help.
    President:
  • 2,110 Answers
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Posted on Dec 09, 2008
  • Sony Master
  • 4,806 Answers
It could be the convergence, adjust the convergence again using FLASH FOCUS.
It is recommended to perform FLASH FOCUS about 30 minutes after the
projection TV is first turned on.
Receive a TV or cable TV program.
Press FLASH FOCUS.
The cross pattern appears and FLASH FOCUS begins to
work. The adjustment is completed when the cross pattern becomes
white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle.
If you perform any other operation while FLASH FOCUS is in progress,
FLASH FOCUS operation is canceled.
Unshielded speakers or other metallic objects can cause picture
distortion if placed close to the projection TV.
If that doesn't sort it you may have to perform an auto set up again!!
kind regards
  • 837 Answers
This is DEFINITELY your TV. I have the same set and had the same "flashing" problem. It is a known problem with the set and Sony needs to fix it. I fought long and hard with them to get mine fixed and paid for. It was out of warranty but obviously a problem that was with the set from day 1. The service bulletin is No. 442R3. If they give you any BS (which they will), don't give up. They need to replace the "A" board. It will be about $600-800 if they don't cover it. Best of luck. It was a nightmare for me. They originally tried to do some other fix on the circuit board by taking my set apart and into the shop. NO DICE. They had my set for weeks. The A Board fix can be done by you and in minutes.
  • Jay Glendenning
    Jay Glendenning Dec 09, 2008
    Well glad I could help .. I hope you get it fixed without all the hassles I dealt with.
    Crayz
  • Sony Master
  • 19,396 Answers
Is this three second flash an option? From description it looks more like a malfunction.
I did not find any option that can resemble the described 3 second flash, are you sure this is not a malfunction?
  • 1 more comment
  • Ginko
    Ginko Dec 09, 2008
    Great you are refusing all sotlutions!!!!!!!!!!!!!!
    Good choice.
    Now you will not see all my comments, if you see this one , give me the exact model number instead of responding to useless comments.
  • Ginko
    Ginko Dec 09, 2008
    Again, give me mopdel number, do not comment and do not refuse solutions.
  • Ginko
    Ginko Dec 09, 2008
    I mean give me the camcorder model, you gave a problem on TVs, and did not even mention you have a problem with a camcorder instead.
  • 107 Answers
Try checking if you cables are secure, This can be caused by a loose cable as the system will cause it to show it as a new connection, What I would like to know is if it is random when it does it or does it happen at spacific intervals?
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    What is the model of the TV?
  • 734 Answers
Ok,
please go to the following link -----
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/293578-sony-rear-projection-tv-kp-53xbr45-powers-then-off.html
Thankss
  • 10,594 Answers
Press Display / Info button on "TV original remote", such display will disappear.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Dec 09, 2008
    If TV is connected with DTV Receiver then 3 Seconds flash is might from DTV receiver.
    To turn off On-Screen-Display, there is only one button available on original TV remote calls..Display...situated in middle of remote just above channel selection buttons, near to TV/Video and ANT button.
    OK, TV is hooked with DTV receiver.
    Let me know is this flash of 3 seconds just started or you just noticed it.
    OK, I got technical information of this 3 seconds flash problem and it requires few components replacement on A board.
    Let me know, can you replace 3 capacitors and 1 resistor on A board. I will let you know what part will be replaced with what part number and description.
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
How can I disable the multi flash on the Olympus e-510 in auto mode
I'm not certain what you mean by "multi flash". I'll give you two answers. 1.) If you are attempting to take a picture under low light levels, the rapid flashing is the camera adding light to the scene for the autofocus to work. You may have to manually focus in these situations if you don't want the rapid flashing. 2.) The autoflash can be disabled with the flash button on top of the camera. Pressing it once will open the pop up flash. Pressing it a second time will bring up a menu on the screen. Highlight the lightening bolt with the line through it and press 'OK". Auto flash can also be disabled by using one of the scene modes such as low light, candlelight, night scene or fireworks.
Oct 13, 2009 | Olympus E-510 Digital Camera
How do i get the trouble codes off a 1989 mazda mpv?
http://img178.imageshack.us/img178/3331/obdikx3.jpg
The above link is to a diagram of your ALDL connector, all you need is a paper clip, straighten out the paper clip and insert one end into the diagnostic test pin and one in the system ground pin (terminals A & B).
Then put the key in the ignition and turn it to the on position but DO NOT start the engine. You will then see the check engine light flash. It will initially start by flashing once, then a pause and then flash twice and it will repeat this three times. That flash sequence indicates 12, which just means the system is operating. Its the flash sequences after that that will give you the code if any are stored.
For instance if it flashes twice, then pauses, then flashes four times, thats code 24. So any flash sequence you get after the initial 12 (flash once, pause, flash twice) you need write those down. Below is a list of diagnostic codes to tell you what the codes mean.
Code 12
1 flash, pause, 2 flashes
Diagnostic: This Code will flash whenever the diagnostic terminal is grounded with the ignition switch turned on and the engine is not running.
Code 13
1 flash, pause 3 flashes
Oxygen sensor voltage stays between 0.35 and 0.55 volts for 30 seconds when the TPS signal was above 0.55 volts. The engine had been running for at least 40 seconds with an engine temperature above 110° F.
Code 14
1 flash, pause, 4 flashes
Coolant temperature sensor signal indicates a temperature of over 284° F for 4 seconds after the engine had been running for at least 10 secondsCoolant Sensor Circuit (high temperature) If the engine is experiencing overheating problems, have those fixed before continuing. Check all wiring and connectors associated with the coolant temperature sensor. Replace the Coolant temperature sensor.
Code 15
1 flash, pause, 5 flashes
Coolant Sensor Circuit (low temperature) Coolant temperature sensor signal indicates a temperature colder than -36° F for at least 4 seconds after the engine had been running for 2 seconds. See above, then check wiring connections at the ECM
Code 16
1 flash, pause, 6 flashes
Charging system voltage was either below 9 volts or above 17 volts for 10 seconds. System High Voltage If the voltage is above 17.1 volts for more than 2 seconds, the Service Engine Soon light will illuminate. Have the charging system checked.
Code 17
1 flash, pause, 7 flashes
PCM did not detect any spark reference pulses within 240 fuel control reference pulses (80 crank revolutions) while engine was running below 1200 RPM. Spark Reference Circuit.
Code 21
2 flashes, pause, 1 flash
Throttle Position Sensor, TPS voltage was above 0.8 volts for 5 seconds when engine was running and air flow was less than 15 gm/sec, or the TPS voltage was over 4.8 volts at any time.
Code 22
2 flashes, pause, 2 flashes
Throttle Position Sensor check TPS adjustment. Replace the TPS sensor. TPS voltage was under 0.2 volts for 4 seconds when the ignition was on. Check for a sticking, or mis-adjusted throttle position sensor.
Code 23
2 flashes, pause, 3 flashes
Inlet air temperature sensor signal showed an air temperature of -29° F for 4 seconds. Manifold Air Temperature. Check the MAT sensor, wiring, and connectors for a possible open circuit. replace the MAT sensor.
Code 24
2 flashes, pause, 4 flashes
Vehicle speed sensor signal showed less than 3 MPH for 2 seconds when engine speed was greater than 3000 RPM and transmission has not been in park or neutral for more than 4 seconds. Or vehicle speed goes from above 18 MPH to 0 in less than 2 seconds without applying brake. This code can only appear when the vehicle is in motion, if it appears when the car is not in motion, ignore it. Check ECM connections, any other problems should be diagnosed by a qualified mechanic.
Code 25
2 flashes, pause, 5 flashes
Inlet air temperature sensor signal showed an air temperature of over 218° F for 5 seconds when vehicle speed was greater than 35 MPH. Check the voltage between the MAT sensor and the ECM. voltage should be above 4 volts.
Code 26
2 flashes, pause, 6 flashes
Quad-Driver sense voltage shows a low voltage when battery voltage should be present, or if the sense voltage shows battery voltage when a low voltage should be present for at least 5 seconds when the engine was running. Have the car checked by a dealer.
Code 27
2 flashes, pause, 7 flashes
2nd gear switch was closed or grounded for 10 seconds when vehicle was in 4th gear, or 2nd or 4th gear switch was open when engine was first started. Gear switch Diagnosis Have the car checked by a dealer.
Code 28
2 flashes, pause, 8 flashes
3rd gear switch was closed or grounded for 10 seconds when vehicle was in 4th gear, or 3rd or 4th gear switch was open when engine was first started.
Code 29
2 flashes, pause, 9 flashes
4th gear switch was closed or grounded for 10 seconds when vehicle was in 4th gear, or 4th gear switch was open when engine was first started.
Code 31
3 flashes, pause, 1 flash
PRNDL indicates a gear other than park or neutral for 13 seconds for 3 consecutive startups when ignition was on, engine was off and vehicle speed was 0. Or the PRNDL status indicators (A, B, C, P) showed an incorrect combination of Lo and Hi for more than 10 seconds.
Check all connectors, and for a faulty switch.
Code 32
3 flashes, pause 2 flashes
EGR System Check vacuum hoses and connections for leaks and restrictions. Replace the EGR solenoid or valve.
Code 33
3 flashes, pause, 3 flashes
MAF Sensor Have the mass air flow sensor replaced.
Code 34
3 flashes, pause, 4 flashes
There was no MAF signal for over 4 seconds while engine was running. Check for loose or damaged air duct, misadjusted minimum idle speed and cacuum leaks. Inspect the MAF sensor and the electrical connections.
Code 38
3 flashes, pause, 8 flashes
The Torque Converter Clutch portion of the brake switch was open and caused the TCC to be inoperative, adjust OR replace switch.
Code 39
3 flashes, pause, 9 flashes
Torque Converter Clutch Check ECM connections, check for faulty Torque Conver Clutch solenoid.
Code 41
Cam sensor signal was not received by PCM for the last 5 seconds while engine was running. Check for faulty connections, or a faulty cam sensor. Maybe also indicate a problem with the vehicle's timing chain.
Code 42
4 flashes, pause, 2 flashes
The Electronic Spark Timing (EST) signal did not change when the ECM applied bypass voltage to the ignition module. Check for faulty connections, or a faulty ignition module.
Code 43
4 flashes, pause, 3 flashes
Knock sensor signal was either above 3.5 volts or below 1.5 volts for at least 20 seconds. Check for a faulty knock sensor, or Mem-Cal.
Code 44
4 flashes, pause, 4 flashes
Oxygen sensor voltage was under 0.25 volts for up to 4 1/2 minutes of closed loop operation, lean exhaust. Check the ECM wiring connections. Check for vacuum leaks at the hoses and intake manifold gasket.
Code 45
4 flashes, pause, 5 flashes
Oxygen sensor voltage was over 0.75 volts for 2 minutes in closed loop operation with a throttle angle between 0.6 and 1.9 volts. Rich exhaust. Check the evaporative charcoal canister and its components for the presence of fuel.
Code 46
4 flashes, pause, 6 flashes
Power Steering pressure switch Check for faulty connections, or a faulty switch.
Code 48
4 flashes, pause 8 flashes
Misfire Diagnosis. Check the ignition and fuel systems.
Code 51
5 flashes, pause, 1 flash
Prom or Mem-Cal Make sure the MEM-Cal or prom is properly installed in the ECM. Replace Mem-Cal or prom.
Code 52
5 flashes, pause, 2 flashes
Cal-Pak Check the Cal-Pak to insure properation. replace the Cal-Pak.
Code 54
5 flashes, pause, 4 flashes
EGR #2 solenoid was out of range for 6 of 8 tests. 55 EGR #3 solenoid was out of range for 3 of 5 tests.
Code 55
5 flashes, pause, 5 flashes
ECM Check for faulty connections. Replace the ECM.
Code 56
5 flashes, pause, 6 flashes
Quad-driver voltage was incorrect for 5 seconds on the circuit connected to QDM "B".
Code 57
5 flashes, pause, 7 flashes
Boost control solenoid did not open bypass valve causing engine torque to be too high.
Code 63
6 flashes, pause, 3 flashes
EGR flow was incorrect. EGR solenoid did not work properly. Have vehicle serviced by a dealer.
Code 64
6 flashes, pause, 4 flashes
Same as Code 63 EGR flow was incorrect. EGR solenoid did not work properly.
Code 65
6 flashes, pause, 5 flashes
Same as Code 63.
Dec 31, 2008 | 1989 Mazda MPV
Continous firing flash
You have a bad cpu chip in this flash . You need to send it ijn the the manufacture at NIkon .
BERRIE SMITH CAMERA REPAIR
770-312-0719 / bbmw@bellsouth.net
Oct 27, 2008 | Nikon Speedlight SB-600 TTL Flash
Button into MC
Step:1 - Make MovieClip at first keyframe in Scene of Flash
Step:2 - Extend timeline of Scene upto hundered frames
Step:3 - Insert Another Layer at main timeline of scene.
Step:4 - Write [First frame] on textbox at First keyframe of second layer.
Step:5 - Write [100th frame] on textbox at Hunderedth frame of second layer
Step:6 - Insert third layer and write [label:-"a"] at hundredth keyframe on timeline.
Step:7 - Make a button inside MovieClip then write the Code on button writen below
on(release){
_parent.gotoAndStop("a");
Step:8 - Look the change in screen.
Note:- The above code is valid for flash versions upto Flash player version Eight.
Sep 24, 2008 | Macromedia Flash MX
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
Random, intermittant blue lines
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
