Question about KitchenAid Microwave Ovens
Will run for about 18 seconds,then gives an F7 error code
My 20 month old KitchenAid microwave will not work. I give it a time and press start, it runs for about 18 seconds, gives error code F7 and stops running.
I had a technician come out, he called the magic number and was told it is the inverter board. They want $176.55 for the part, $120.00 to fix it and charged me $78.00 for the first service call. All for a $600.00 appliance!
Am I being ripped? I checked the warranty and in the second year it only covers the ;electric element and solid state touch control system parts". No mention of an inveter board.
I don't see it on recall either. So, any ideas? I hate to pay $400.00 to fix a $600.00 microwave that is not even two years old!
Help!
  • 2 more comments
  • jonmarks Dec 09, 2008
    Model is KHMS 2050 SSS
  • jonmarks Dec 13, 2008
    Thanks for the attempt to help. No, the service guy did none of the things you suggested. He walked in, opened the microwave door to get the serial # and Model, then did as I explained, i.e. ran the thing for about 18 seconds until the error code came up, then called KitchenAid's service tech number and told them the error code and the accompanying message: "Error Code F7, HV SMPS feedback, call for service." They asked him for the info, he told them and they said it was the Inverter Board. He then asked for payment ($78.00) and left with a promise to call me with the amount for a return visit, plus parts and labor. Next day he called to say it was $176.55 for the part, plus $120.00 for labor, plus tax. So, roughly $400.00 to fix a $600.00 appliance.
    Question: Is the Inverter Board the equivalent of an"element" in this microwave or does it actually have an electric element? My warranty covers the "element" in years 2-5, but my husband, an engineer, says he does not believe this microwave has an electric heating element. Is this so? Any help would be appreciated.
  • William Miller
    William Miller May 11, 2010
    Did the technician take the time to do all the tests called for on an error code F7 as shown below?
    F7 Power to magnetron interrupted
    1. Unplug microwave oven or disconnect power.
    2. After 40 seconds, check to see whether this solves the problem.
    3. Unplug microwave oven or disconnect power.
    4. Check cooling fan operation
    5. Check the magnetron.
    6. Check P65 connection on the relay control board.
    7. Check the P56/P66 connection between relay board and relay control board.
    8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
    9. Check operation of all interlock switches.
    10. Replace all parts and panels before operating.
    11. Plug in microwave oven or reconnect power.
    12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
    13. Replace inverter.
    14. Replace all parts and panels before operating.
    15. Plug in microwave oven or reconnect power.
    16. If problem persists, unplug microwave oven or disconnect power.
    17. Replace relay control board.
    18. Replace all parts and panels before operating.
    19. Plug in microwave oven or reconnect power.
    20. If problem persists, unplug microwave oven or disconnect power.
    21. Check for reversed plug connection on controls or loose wiring.
    22. Replace all parts and panels before operating.
    You say "he called the magic number"? Does that mean he called in to someone for technical assistance?
    If so I doubt that he did the tests.
  • Victor Lourenco Oct 24, 2012
    When I checked the voltage at 4903-1 on relay board it was 120 Volts however when the microwave is turned on it drops to t o zero. Should it drop to zero? Should it not maintain at 120V to activate the inverter. Unfortunately, I don't have a spec sheet nor I am able to get access to one. Any help?
  • KitchenAid Master
  • 9,086 Answers
Just as I suspected...
The "element" as it is so inaptly misnamed in the case of this warranty document, is actually the "magnetron", which should normally have an extended warranty beyond the normal 1-year (I assume) parts and labor warranty anyway.
The magnetron may be the culprit here, but a thorough check of the points on my previously posted list is in order to determine the actual cause of the problem.
Since your husband is an engineer, I would suggest that he invite a colleague over to help and to provide some backup for any heavy lifting if it should need to be removed from the wall.
Safety first after all!
You can download Kitchenaid Whirlpool owner's manuals and installation instructions here in case it needs to be taken down during troubleshooting.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
Having same problem. Can I buy the part needed myself and replace it? How would I figure out which part that is? Also have a Kitchenaid Fridge (I have repaired myself) and a Kitchenaid Stove/Oven (I have repaired myself). Thought these things were high end!!?? Anyway, maybe microwaves are more complicated so not sure if I should work on it or not.
Posted on Mar 12, 2011
Thanks to the previous posters who shared their info and knowledge. I'm having the same problem with my KitchenAid microwave; but I am only getting the F7 error intermittently. I don't have my model # handy at the moment, so not sure if it is the same model - it's been in light-duty service for about 6 years. Sorry I don't have solution yet; I'll post back if I get this solved. I'm not impressed with KitchenAId appliances at all. My dishwasher is also KA, and also JUNK! No more KA for me - EVER.
Posted on Aug 12, 2010
  • Ace Feb 29, 2012
    Have some further info re: this issue. Discovered that the F7 ERROR was occurring when the "blade stirrer" was not turning. This is the metal propeller looking part, that you can see through the round transparent plastic cover/window located on the top ceiling, inside of microwave. When the mic is operating properly, this stirrer propeller slowly rotates. Mine is frequently "sticking", causing the F7. .
    The low tech solution, which I do not really recommend, is to tap the top of the microwave ceiling with a closed fist; this seems to free up the stirrer to rotate. Another low tech solution, which I haven't tried yet, would be to use a strong enough magnet on the outside of the "window", to manually turn the stirrer, to free it up, so to speak.
    A better solution would be to replace this part(s). The "stirrer motor kit" is Whirlpool part # AP3135927 ($86.49 as of today) - "includes new motor, stirrer cover, plastic rivets and hardware to install upgrade kit." If you only need just the "blade stirrer", the part # is AP3133620. I suspect if your stirrer is sticking that you would need the whole kit.
    To prevent this problem in the future, don't buy anymore Kitchenaid/Whirlpool junk.
    Hope this helps someone.
  • Ace Feb 29, 2012
    Note:
    The solution above applies to Kitchenaid microwave Model KHHS179L. Should you also have a propeller stirrer issue, be sure to check replacement part numbers for your specific model.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
F7 Error code
Please reply back with your model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
May 30, 2008 | Microwave Ovens
Error Code
F7 problems are usually caused by poor connections. I suggest to unplug the ribbon connector off the control board and cleaned the copper connectors using alcohol or with a pencil eraser. If that does not work the touch pad may be defective.
Jan 19, 2008 | KitchenAid KHHS179L Convection/Microwave...
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
Microwave Ovens Logo
3,515 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
