Question about GE JVM1850 1000 Watts Microwave Oven
BLEW A FUSE ?
I CLOSED THE DOOR AND THERE WAS A FLASH . ONE OF THE LIGHT BULBS BURNED OUT . THE TURNTABLE STOPPED.CAN I ACCESS THE FUSE WHILE THE UNIT IS IN PLACE? AND HOW? JVM1870SK03 GE SPACEMAKER 1800
  • cassietashah Mar 22, 2009
    EXCELENT
    EXCELENT SERVICE ! EXCELENT WEB SITE ! LOTS OF INFO FOR DO IT YOURSELFERS AND THE REST OF US TOO! MY MICRO WAS FIXED QUICKLY EXPERTLY AND C H E A P L Y !
Microwavedisplay.com is a fraud. sent my display a month ago. Check was cashed right a way. I sent bunch of emails and voice mails but no response. Clearly a fraud
Posted on Nov 23, 2010
Beware of this place, microwavedisplay.com. Of late, some are seeing very long turn around times. They don't respond to emails or answer the phone. See http://www.whoila.com/blog/?p=725 for some recent experiences.
Posted on Apr 18, 2010
  • logicunit Nov 23, 2010
    microwavedisplay.com is a fraud. sent my display a month ago. Check was cashed right a way. I sent bunch of emails and voice mails but no response. Clearly a fraud
  • burned up Dec 02, 2010
    he will cash your check but anything after that is in question,might make more sense to buy new microwave
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site.
Posted on Dec 13, 2008
  • ans7
    ans7 Oct 03, 2011
    I DO NOT RECOMMEND MicrowaveDisplay.com and William Miller! Promises 2-3 week turnaround, instead takes months and months and months. Cashes check immediately though. Doesn't respond to e-mails or calls. Thief and fraud at worst, liar and horrible business manager at best. STAY AWAY!!
Posted on Oct 03, 2011
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
Why does the turntable spin when the door is closed ?
this is normal thats the way they heat from in to out
now if you open the door the light is on
if it does not just change the bulb 10w 120 vac e14
Sep 16, 2015 | Microwave Ovens
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Lights up counts down and thats it no fan no spin no heating
I believe that there are to fuses inside this unit. One feeds the electronic components and the other feeds the turntable and the magnitron. Un plug the unit and check both fuses, you might get away with this cheaply. Please let me know if this helps. P.S. if one of the fuses continues to blow its time to get rid of the unit, because if they go bad they get stronger and very dangerous. What normally would boil water at 3 minutes could change to 45 seconds. Be careful.
Aug 13, 2009 | Zanussi ZM24ST Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Flash and Bang on Closing Door
Since you know that the bulb is blown that needs replaced. I would go ahead and replace the bulb and see if it works. I doubt that it will. If not unplug the unit and remove the exterior case. Locate the secondary fuse and replace it with the same size and rating. Plug in and try but be prepared as it may do the same thing again. I am not sure what you mean by 'lay up' your unit. If it was not running (heating) it should not be the magnatron. Sounds like the bulb blew taking out the fuse which would cause the other problems you described following the flash. Good luck.
Jun 12, 2007 | Kenmore 63672 Convection/Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
781 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
