Question about Bosch Food Mixers
Bosh model UM30710012104 Blender part broken
Mixer/blender model#UM1071001204. The plastic drive for the blender broke; thus the blender cannot connect and turn.,
Where can we get the part or have it repaired?
2 Suggested Answers
xalint1
  • 152 Answers
SOURCE: Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Posted on Aug 04, 2008
My blade assembly broke. Can I get a new one for my Maxi 4000
replacement can be found on amazon, take a look here: Amazon com Vitamix blade assembly. I hope this was helpful. Cheers
Jan 16, 2013 | Vitamix Vita Mix Maxi 4000 Commercial...
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
Tipped over my blender, broke the black plastic piece that raises and lowers the top, and now it is stuck in lower position. Won't move.
Blender? This is a form about Kitchenaid mixers . . . assuming that's what you have,and it is a stand type mixer, look at this page:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
And you will see the linkage which was bent/broken. Hopefully you will be able to either straighten the bent part or replace it if it is broken.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The black plastic piece that makes our blender spin broke. How can I get it repaired?
Yes, it is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here: http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Feb 06, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Teeth keep stripping on the Bosch blender.
Is there a lubrication issue? Is there a bind or load to the drive after the gears? What has changed since it worked well? P{ancake batter would not be sufficient load to eat gears. Are you changing speeds under load?
Oct 04, 2009 | Bosch Food Mixers
Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Mar 23, 2009 | Bosch MUM6610 Universal Series Stand Mixer
800-275-8273
Monday - Friday
Aug 04, 2008 | Wolfgang Puck Stand Mixer
Food Mixers Logo
408 people viewed this question
Top Bosch Food Mixers Experts
Oscar Netto
Oscar Netto
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
