SOURCE: Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email [email protected]
SOURCE: Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Testimonial: "That was the trick. I knew it had to be something simple but I couldn't figure it out."
