I have a philips 42pf5321D/37 tv. last night, all of a sudden, it shut off and cant turn back on
Slinteriors
  • 8617 Answers
SOURCE: 4 blinking red lights
From what I am able to find out there is a problem with the main power supply or thermal shutdown when the lights are red flashing. have you tried to reset it?
Posted on Apr 11, 2008
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
My 'Philips 51PP9200D/37' TV picture is distorted and bowed along the bottom. There is like a "bubble". It has been there for over a week. It went away for the night last night but is back this AM.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 01, 2010 | Philips 51PP9200D Television
Tv get wet and not turnig on
when electronics get wet they tend to short out.
so some part of the electroncs is damaged.
you will have to take it in for repairs
Apr 26, 2009 | Televison & Video
TV will not turn on
Good Morning Chris,
OK, first of all lets unplug the TV and wait 15 minutes for the High Voltage to discharge.
Remove the back and follow the power cord to the power supply. Somewhere around there you should find a fuse. (there may be more than one) get a bright light to look inside and try to find as many fuses as you can. Remove each fuse one at a time and check them with an ohm meter.
If you don't get a good solid reading on any of them replace the fuse or fuses with the exact same rating. Even if you get a reading and the display is jumping around and will not stablize, replace the fuse. Usually a good fuse taken out of the circuit will display a good steady reading on the meter.
I hope this solves your problem.
Have a great day!
Mar 26, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture on tv. model 42pf5321d/37. red light flashing on lower right. flashes 4xx see Morgan ref. 719nt
Purchased new Pansonic TV,, old one [2 years] was not projection tv. In for repair for kids.
Oct 07, 2008 | Philips Televison & Video
I have PHILIPS 42pfl5332d/37. I was watching tv, and suddenly the screen goes blank. There's a blue light that turns on when the tv's on, however when the screen went blank, that blue light turned orange...
I don't have that problem, my problem is that I lost my remote control, so I can't configure de channels.. I just have 4.. =S.. I can see the menu, but in the part that say start configuration, I cant activated without the control, I don't know what to do.. aNybody Knows??
May 19, 2008 | Televison & Video
Apr 11, 2008 | Televison & Video
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
