Copystar CS-1500 Copier Problem
Thanks for responding! So we first got a message saying that toner was low so we replaced it. Now that we have replaced it and put a new one in the copier won't copy anything. It just shoots out blanks.
  • humey51 Dec 10, 2008
    We removed the seal. Secondly, I am a novice when it comes to printers and such. What is the charge corona? Discharge corona?
  • humey51 Dec 22, 2008
    I have yet to fix the problem. I was unable to find any hairlike wires in the copier.
    President:
  • Office Equip... Master
  • 990 Answers
Check the charge corona and discharge corona wire unit either broken wire or the contact no good! one more thing when you replace toner cartridge did you remove the seal?
Posted on Dec 10, 2008
  • 1 more comment
  • Everett Lin Dec 10, 2008
    the charge corona wire above the drum, the discharge corona wire beneath the drum the charge one only one hairlike wire, the discharge have two
  • Everett Lin Dec 21, 2008
    Hello; DId you settle your problem? Please return to me I'm here to help you up!
  • Everett Lin Dec 23, 2008
    Hi, Sir; Do you know the drum unit ,if you know try to remove it out, now on the top of the drum you will find a metal box (1' x1"x12") inside this box have one hairlike wire, check it out is that broken, one more thing you may try, push developer unit close to drum unit sometime it loose cause the problem too.
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
I have an error code C-7 980 on a Copystar 1500. What does that mean?
This is a drum related problem. The waste toner is full. Remove the drum unit, remove toner cartridge and unscrew 2 chrome screws on on the left side of the unit. empty the waste and screw back the screws. replace toner and put back in the machine
Oct 26, 2010 | Copystar CS-1500 Copier
AP MESSAGE
Keep opening and closing the toner door to force toner feeding
Jul 06, 2010 | Copystar CS-1500 Copier
C-7 990 error code just keeps showing up on copystar 1500 copier
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine board
Aug 19, 2009 | Copystar CS-1500 Copier
COPYSTAR 1500
the waste tank is full, remove the drum carriage. on bith side remove screw( the one who is inside the hole) dump the waste toner
Jun 22, 2009 | Copystar CS-1500 Copier
Toner cartridge
while pressing the center of the cover pull out the cover then bring it upward,
Jan 14, 2009 | Copystar CS-1500 Copier
SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Dec 05, 2008 | Copystar CS-1820 Copier
Did you remove the drum unit when fitting the toner? Try reseating it.
Nov 25, 2008 | Copystar CS-1500 Copier
51 people viewed this question
jasbo
jasbo
