Hi, I have water dripping from my a/c, on the inside
  • tim0975 May 11, 2010
    the outdoor unit is dripping water?
  • 334 Answers
The condensate drain line is probably clogged.
Find out where the pipe exits the home, and attatch a wet/dry shop vack to the end of the drain line, close it up around the pipe as much as possible and trun it on.
These typically get clogged with dust, dirt, pet hair, mold etc.
They usually clog at the elbows, P-traps and the inlet coming from the drain pan. There is an internal drain pan in the unit that catches the condensation. When the line clogs the pan overflows and you have water dripping from the unit.
There is also a small chace the pan has a hole in it, but thats fairly rare. There is also a chjance that if the unit is not level the water will overflow the pan before it can drain. (most pans are only 1 to 2 inches deep.) Make sure the unit is level or veryslightly lower toward the drain side.
Posted on Dec 10, 2008
Saeco odea does not brew coffee, all the water goes in the drip pan
Hello, the water in drip pan is clea water ot coffee water?(brown). Take a pucture inside machine with no brew unit inside.
Aug 27, 2017 | Saeco Coffee Makers & Espresso Machines
Hi, my Haier ice maker seems like there's water dripping when when the ice drops in the tray so the water that drips together with the ice freeze together and makes it difficult to use single blocks.
yes ive seen this before , it turns out that the automatic valve that lets the water in isn't shuting all the way off , something is maybe stuck inside it (no water filter on line ??) also you could just replace the valve too , that works too !!
Jan 10, 2017 | Haier Refrigerators
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
After washer has stopped, it contunes to drip inside the tube
Start the washer in a normal cycle, once it starts to fill, unplug the unit from the wall. If the water stops completely its not a water valve issue. If it still drips, replace the water valve to the washer. Good Luck
Jul 12, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Drinking water dispenser inside my Maytag MFS2561 is dripping.
Hi Bud, welcome to FixYa. To address the water drip problem, I have 2 question's. Have you recently changed the water filter (or done anything else) and can you double check you have correctly posted the entire model number ? Let me know and I'll be glad to continue to help you from there.
Regards,
Macmarkus :)
Nov 03, 2011 | Refrigerators
My split system R/cycle air con is dripping water drops from the inside unit.
hi,
If this happens just recently, most probably the cause of dripping is that there is something that blocks and restricts the condensate line and it causes the water to overflow and drips.
Try to check the line if it is free from any obstruction.
Hope this help you.
Don't forget to rate me. Thanks...
Regards,
John
Jan 12, 2011 | Heating & Cooling
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water driping inside from ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
Jul 04, 2009 | Refrigerators
Heating & Cooling Logo
409 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
