2003 Lincoln LS Logo
Posted on Jul 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 Lincoln LS hot air while stopped cold while driving
After having my condensor disconnected after a radiator replacment job, I had my vehicle's AC system vaccumed and recharged by a friend who works at one of the major local dealerships. My AC now only works when driving. If I am stopped it blows warm air NOT hot. As soon as I begin to drive or if I rev the engine above 1000 RPM while stopped it will blow Ice cold air. I have checked the compressor and it is engaging while stopped but yet no cold air?? Cooling fan is also running normally while stopped. Really confused.
Marvin
Level 3:
Top Expert:
  • Lincoln Master 85,242 Answers
  • Posted on Jul 09, 2012
Marvin
Lincoln Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29051804
Points
266281
Hello
Based on what you have said and my 30 years a Ford dealer tech I believe you have a slightly low AC system refrigerant charge due to a small leak at the AC compressor or the AC line connections. I would have a shop hook up a set of gauges to monitor the pressures at idle and see just how low it is. DO NOT ADD UNTIL YOU KNOW HOW MUCH IS NEEDED, YOU CAN LOCK UP THE COMPRESSOR.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Mar 13, 2009
SOURCE: 1999 Lincoln Navigator Heating Problem
I would check the level of your coolant first and foremost. A lot of times failing to prime the coolant after a large procedure like you just had will be the cause. Also, Ford (lincoln) is notorious for their vacuum powered systems failing which is what controls the baffle on your cooling system to allow the hot coolant from the engine to heat the air in your heating system. Hope this helps
Anonymous
  • 7 Answers
  • Posted on Jun 11, 2009
SOURCE: The a/c in my 2001 lincoln ls isn't blowing out cold air.
I've seen no mention of the 10 Amp fuse under the hood. Has anybody checked to see if that is blown? Mine has blown 3 times in the last 2 months.
Anonymous
  • 62 Answers
  • Posted on Jul 17, 2009
SOURCE: 2002 Lincoln LS V6. AC blowing hot air but
its probably the compressor cutoff switch cutting your compressor off at the wrong time and causing your ac to blow hot. that switch is under your hood right on top of the engine easy to get to. I hope that helps you out!
Anonymous
  • 11 Answers
  • Posted on Aug 05, 2009
SOURCE: ac blowing hot air on 2005 lincoln ls. just sarted today
Needs to be recharged and you more than likely have a leak somewhere
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 04, 2009
SOURCE: heat blows out driver vent when ac on
this problem is caused by a defective air temperature control blend door actuator motor, it is about center of dadsh in air ducting, it moves the door that diverts air for cold from ac or hot from heater, you must remove the dash to repace it, about a 15 hour job fotr a home mechanic with a factory repair manual, nearly imposs without one.
2answers
2000 lincoln ls 3.9 v8 boiling and running hot
check, temperature of upper radiator hose vs. lower radiator hose, also if there are any cold spots in radiator usaully indicates bad thermostat. all hoses and surface of radiator should be hot in order to keep engine cool
1helpful
3answers
Car run hot what is the problem
First thing to check is probably a stuck thermostat. Then the water pump. Head leak. The price and ease of most thermostats is usually replaced first, then further troubleshooting if needed.
2answers
I have a 2003 lincoln ls v8 it keeps overheating.i have nwe thermostat no oil in antifreeze no milky oil no smoke out tailpipe an no leaks wat could b my pob
There is an Auxilary Coolant Pump, you can
check out, below the coolant control valve,
against the radiator near the bottom, on passenger side
Wouldn't a repair shop have figured out the problem ?
2answers
04 Lincoln Aviator Just changed oil filter adapter gasket and now its running hot. The new gasket was just like the old one and I replaced the coolant. I noticed the upper radiator hoses are hot, but the...
You have air in the system
It may work it's way out to the
recovery bottle over time as
it cools and draws in more cool,
so keep container full
I"m not sure if you have a vent hose
to bleed my lincoln ls does
Remove the radiator cap,warm up
when thermostat opens add more
coolant 50/50 or 60/40 Yellow GO5 I
believe
My AC only works when the car is in motion. It blows warm air otherwise.
Sound like maybe your a/c condensor fan is not working, should come on with a/c on, the fan sit in front or back of radiator, condensor is bolted to the front of the radiator, if its not working at stops no air blows through condensor and pressure will get high and a/c wont blow cold, while driving air is running through condersor so a/c will work fine.
2answers
When i stop the car the air in the car get hot but when i'm moving the air runs good.What could be the problem
Have your a/c condensor fan check out, sit in back of the radiator, fan should always be on when a/c is on to reduce the freon pressure in the condensor or a/c will not get cold till air goes through the condensor while driving down the road, no air blows through at stop light because fan not working so a/c will not work right.
1helpful
Lincoln ls V8 2003 engine temperture in the middle ?
You shouldn't hear the fan too much while in the car. It won't start to run until certain conditions are meet. Try leaving the A/C Off or put it on Auto and hit the A/C buttom off. I don't know how hot, the ambient air temp is, where you are.
Your not talking HAVC Blower inside are you?
I have a 2004 V8 and the radiator fan is quiet
A/C blows hot air intermittently
this is clear that your aux fan cooling your condensor is not working ,your a/c system is overheating and with speed you are forcing air through your condensor doing the job of the fan.
8helpful
Lincoln lse 2005 ac blowing hot air on left side!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If your LS is blowing hot air on one side of the dash and cold on the other the problem most likely is the Dual Coolant Control Valve. The DCCV is used to control cabin temperature. This valve is mounted down low on the passenger side of the radiator fan shroud, and has 3 coolant hoses connected to it. This valve if found to be faulty will need to be replaced to correct the condition.
1helpful
Ac not working blowing hot air
Check to see if your radiator is holding pressure. Fell your radiator, let it idol and make sure nothing is leaking. If you have a small leak, try running through a bottle of MAC's(or any brand) leak stopper. It should work. But make sure you follow all the instructions, when it says let it idol for 30 minutes, let it idol for 30 minutes. I have seen/found Lincoln LS's seem to have quite a few leaks that pop up on it's radiator, the plastic thermostat housing and it's cap. Have fun.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
