Question about LG KU990 Viewty
Calibration of LG KU990R
I am not able to scroll up or down the menu list. The scroll bar is not working. The scroll bar is coming to the extreme right of the screen. Is it the problem of calibration? in that case how to calibrate the mobile?
Actually I was trying in a wrong way. To scroll through a list of option, touch the last item visible and slide your finger up the screen.The list will move up so more items are visible.
Posted on Dec 11, 2008
My LG KU990R viewty always freezes when selecting the camera and restarts soem seconds later. It also shuts down after a while being non-active. If active the phone + sms part is working fine.
I need a red or black housing or just the battery cover for my LG Ku990r (I have the version with the camera lens & switch).. Please help :/
Oct 10, 2009 | LG KU990 Viewty
Screen goes blank when being called or calling out!!!
Reviewed by Geoff_W from UK on 26th Jun 2009
A GREAT PHONE - spoiled for many by the screen blanking problem on making or attempting to receive calls. Some seem to have solved the problem by removing screen protectors, but this didn't work for me. I sent the first phone back for a replacement - but this was just as bad. The problem seems to be the result of a poorly calibrated proximity sensor - but you can re-calibrate it. The following procedure worked for me, but it's potentially dangerous, and could ruin your phone if you're not careful - YOU HAVE BEEN WARNED! 1. On the phone keypad enter the following code: 1809#*900# to bring up the engineering settings menu. 2. Scroll down to the entry called OTHERS and select it. 3. Scroll down this menu to the entry called PROXIMITY and select it. 4. You should see three options: Enable, Disable & Start Calibration 5. Select Start Calibration - after a few seconds it will return a new figure (mine was 3627) 6. BACK right out of the menu system, and make a test call - it should blank the screen when you hold it to your ear (or when you hold a finger near the sensor), but come back on again when you remove it. It worked for me - so now my Viewty Smart works just as it was supposed to. This information is offered without warranty - Good luck if you try it! 4 stars for the phone design - loses one for the delivery set-up, and lack of documentation of a fix.
This method worked for me.
Jun 21, 2009 | LG Cell Phones
Freezes?
try this as it is a wide spead problem with lots of ps3s
Please run through the following, go through in order.
1) Delete the game's install data. This is done via the PS3 options. Scroll along the cross media bar until you reach the 'Game' tab, now scroll up / down the list until you reach the 'Game Data Utility' Enter this and locate the (GTA IV ) option or the game thats freezing option. Highlight this and press triangle once, from the menu select Delete. This will delete the game's install information.
2) Delete the game's save files. To delete any save files you will need to do the following. Scroll along the cross media bar until you reach the 'Game' tab, now scroll up / down the list until you reach the 'Save Data Utility' Enter this and locate the GTA IV / other game name option. Highlight this and press triangle once, and from the context menu select Delete.
3) Disable your Internet connectivity for the PS3. To do this scroll along the cross media bar until you reach the 'Settings' tab, now scroll up / down the list until you reach the 'Network Settings'. Now scroll down to the Internet connection option and press x, now select the disable option. Once this has been done unplug the ethernet cable if you are connecting to the Internet if using this.
4) Disable the console's information board. To do this scroll along the cross media bar until you reach the 'Network' tab, now scroll up / down the list until you reach the 'Information Board', highlight this and press triangle. From the menu select 'Do not display' Press X to confirm this.
5) Disable Media Server functionality. Scroll to Settings, now scroll up / down to 'Network Settings' select Media Server connection. Once this has been done press triangle and change the option Disabled.
6) Delete all of the system's Internet cache. To do this scroll along the cross media bar until you reach the 'Network' tab, now scroll up / down the list until you reach the 'Internet Browser', highlight this and press X. Once you browser opens press the triangle button once, from the new menu highlight the 'Tools' option and press X. Scroll down the menu until you reach 'Delete Cookies' and press X. Confirm the files deletion. Repeat this for 'Delete Cache'.
7 ) Turn off the PS3 screen saver. Use the cross media bar to scroll to 'Settings', select 'Display Settings'. Now highlight 'Screensaver' and set this to 'Do not use'.
8 ) Once this has been done, manually restart you PS3 by holding down the power button for 5 seconds it will beep once and then shut down. Release the power button and re-press it and hold for about 5 seconds. The system will then boot and reset all display settings. You will be prompted to reset your display settings to how you require them.
9) Once restarted please try the game again, you will be prompted to reinstall.
Once the game has started please turn off the following features:
1) The game's auto-save. Press Start, Game, and locate the Auto-save option. Turn this off.
2) Turn off the game's flicker filter. Press Start, Display and locate the Flicker Filter option. Turn this off.
3) Turn off the controller vibration feature. Press Start, Controls and locate the vibration option. Turn this off.
if this fails then you`ll need to call sony and i believe they charge for a fix...
Sep 26, 2008 | Sony Playstation 3 (PS3) Console
Lg vu screen responsiveness
You may try touch calibration.
To do this, first go to the main menu.
Choose the last tab on the right-hand side of the screen and choose 'More'.
Scroll down to 'Touch Calibration', selct, and then follow the instructions that appear on the screen.
Aug 23, 2008 | LG Vu Cellular Phone
Scroll bar wont work
Hello
I can't say for sure without seeing the phone myself.
It may be.
If you go to a local phone shop and test the same model in the shop, see if it operates the same way as yours. You can also have the guys in the shop check it out.
Let me know if you need anything else
Thank you,
Ekse
Jun 25, 2008 | LG KU990 Viewty
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Garmin 2610 'ok' doesn't work
Try brush around the edges of screen...press the edges and work out dirt.... Let us know. See other posts...Same problem with screen touch system not responding.
Nov 10, 2007 | Garmin StreetPilot 2610 GPS Receiver
Touch screen does not work.
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
LG KU990 Viewty Logo
330 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
