The red clamp on the charger goes to the + sign on the battery. The black goes to the -. I you want a deep charge(best) set the charger on 2 amps and run it for 8 to 12 hours. If you need to get the car started, set the charger on 225 amps for just a couple of minutes. Start the car while it is on..2 amps can charge forever. 20 amps for 30 minutes. 30 to 40 amps for 15 minutes. 225 amps for five minutes..DO NOT charge 20+ amps for hours. It will kill the battery
<span>Your Phone Bettery Fault So Please change Bettery<br />First Bettery charging Full and Swich On The Phone <br />I Hope Problem will solved</span>
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Sounds like your battery is just too dead, has enough juice to light up the system for a minute but cranking drains it and if it wont charge then deff fried, you could try removing the battery and starting the car with cables to confirm the starter still works. If a bettery is too dead then when you are jumping it, it takes to much of the power just trying to get through the battery.
Do you drive it every day? The clock can kill a battery in 2 days if it is not run. How did you check the battery>? Volts, amps?,Electrolytes? The battery must maintain minimum 13.5 volts at all times. The electrolyte fluid can tell you a lot about the condition of a battery, One dead or weak cell, you might as well trash it. Just because it is a newer battery doesn't mean it is good, I've taken them off the shelf, dead. If you have an amp meter on the dash, it should always show charging, or 13+ volts, a light will only show when it is not charging or a very low battery is being charged, depends on the car. Get one of those floaty ball things at the auto store and check the water in the battery, and make sure it is up on water, bottled water works good, distilled type, no minerals. Hope this helps.
