Question about Hitachi CP-X270 Multimedia Projector
Hitachi CP-X270 The projector won't show any blue. I've checked the settings, and nothing is wrong there. I believe it is a mechanical problem. I think it could be a bad ground or something dealing with one of the color screens, but I'm just not sure. Any help would be appriciated.
  • 34 Answers
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
Posted on Dec 05, 2007
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Posted on Feb 03, 2008
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not please see page 39 of the user's manual (download found below)
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Posted on Apr 24, 2008
SOURCE: Hitachi CP-S235 Data Projector - yellow tint to projected picture
Replaced cable and the problem was solved.
Posted on Feb 12, 2009
  • 149 Answers
SOURCE: problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Posted on Sep 07, 2009
0 characters
1 Points
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Toshiba projector
Change it to clone the display. It is probably set to extend your desktop not to clone.
Nov 12, 2007 | Hitachi CP-X270 Multimedia Projector
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
Toshiba TLP S10 Projector That link will take you to the owner's manual. It should answer whatever questions you have.
Aug 28, 2007 | Hitachi CP-X270 Multimedia Projector
Hitachi CP-X270 Multimedia Projector Logo
15 people viewed this question
Top Hitachi Multimedia Projectors Experts
Electro Med Services...
Are you a Hitachi Multimedia Projector Expert? Answer questions, earn points and help others
