Question about Canon Rebel XT / EOS 350D Digital Camera
Camera turns on, info window posts flashing 0000s, many icons
My battery is charged, I can turn on/off camera, tried different Canon lens, can use menu, view pictures on memory card. Sequence of numbers:
0000-00000 9 sometimes shows in the first 0 and 8 sometimes shows in the 6, 0 spot.
looking for a respons before I send away--at Christmas!!
  • 4,806 Answers
Restore settings
kind regards
Posted on Dec 09, 2008
  • 734 Answers
try a reset ..
if not works then..
you needs a repair from service center.
Thankss
  • 10,594 Answers
Try to reset / initialize camera.
If still shows error, call nearest Canon service center.
Thank you.
  • Shahid Electronics
    Shahid Electronics Dec 09, 2008
    This is in response of your Ask Me query..
    http://www.fixya.com/support/t1355384-re...}
    If you don't have user manual, download it from Canon Support and go to page 35 for details of Reset / Restoring camera's default settings operation.
    Good luck
Canon DSLR will not turn on
Hi there,There are a few things we can try/check here!
1.Turn the camera OFF. Remove the battery and clean the contacts (shiney metal strips) on the battery.2. Remove the lens and clean the lens contacts.3. If you have a body cap, put it on the camera (no lens, just to keep dust out right now).4. Reinstall the fully charged battery and turn on the camera.
It should start up. If so, turn it back off and reinstall the lens.
Also, be sure to check all the doors/hinges on the body. These are found on the battery and the memory card. They have electrical contacts on them that need be to be fully closed.
If possible, try a different battery (a friends, or take it to your friendly neighbourhood camera shop).
Hope it turns back on!
May 07, 2012 | Canon EOS Digital Rebel XTI Digital Camera
Sd10 elph green
I suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries. you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
Oct 11, 2008 | Canon Cameras
Camera turns off when pressing shutter button
Sounds like a compatability problem. If available, try a genuine Canon battery new and fully charged.
Jun 09, 2009 | Canon EOS 40D Digital Camera
Hi, all of a sudden, my Canon Rebet XT gave me a faint flashing error 99 message. It won't turn off and the red light at the bottom right of the screen stays on even when I turn my camera off. I have to...
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4.clean all lens contacts on lens and camera with a rubber eraser
5. Insert a fully charged battery, and turn on the camera.
6. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
>from :
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
May 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon EOS 400D and when i turn it on it works fine but when i start to use the flash it doesn't flash i get on the screen ERROR 99 ! what do i do ?
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 14, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Canon XS - Lens malfunction & won't turn on
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
