Question about Sharp 21" Multi System Stereo TV
I need a code for a sharp 35" tv to program my rca remote
I have purchased a rca remote at wall-mart, and it did not have a code list inside. I need the code list for sharp 35" ,older model tv.....thanks
5 Suggested Answers
  • 1694 Answers
SOURCE: SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
www.remotecodelist.com ......................................T.
Posted on Mar 28, 2008
SOURCE: need codes to program universal remote
0093, 0165, 0039, 0386
Posted on Jun 13, 2009
  • 317 Answers
SOURCE: I have an older Sharp
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Posted on Jul 06, 2011
caroldon
  • 17130 Answers
SOURCE: i have a sharp x flat tv component-in/mts model #
Please check the links below and seeif they help to match for the codes provided.
http://www.xdiv.com/remotes/
http://www.remotecodelist.com/remotes/rca/rca.htm
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Posted on Oct 25, 2011
I have a rca remote rcrn04gr. how do I find the code to program it to my sharp tv mod# lc37d42u
The RCA website should have a list of codes for your sharp TV or instructions on how to program the remote.
Feb 18, 2015 | RCA Televison & Video
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
I need the code for an RCA remote model RCR311W for a sharp tv
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Mar 04, 2011 | Televison & Video
I have a rca remote and my tv is made by share
Is your RCA remote a universal remote? Do you know the model number of the remote, usually found inside the battery cover?
You can usually find the codes from: http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
FIND your model number, GOTO Support & Service Manuals, THEN select CODE LIST.
If it is a universal remote, you can program it to do BASIC functions for your Sharp TV, like power on/off, mute, channel & volume up/down, pretty much it. You wont be able to access any of the menu functions.
Nov 30, 2009 | Sharp Televison & Video
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
I need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Jan 13, 2009 | RCA Universal Remote Control
Remote controls
have your problem fixed get a / one for all / remote controe it has the tv in that you have in the list cost little to nothing to get it go to wall mart please reply thanks p.s. rca dont have codes for that tv all for one does
Mar 28, 2008 | Durabrand DWT1905 TV
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
