Question about Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F Paper Jam 01
We're getting "Paper Jam 01" error message, but no jammed paper in evidence. The printer isn't able to pick up paper from the bottom paper tray. It makes grinding noise. Is still able to feed paper through the manual paper feed.
Any idea what's going on?
Thanks!
  • 2 more comments
  • volunteernab Dec 09, 2008
    Thanks - I tried cleaning it and still no success. The paper just isn't getting picked up.
    I realized through experimentation that the grinding noise must be caused by that rubber piece that flips over (next to the black thing you press to fool the printer). When it gets pressed the wrong way it makes that grinding noise.
    Tried the cleaning option... still having trouble. I can definitely still print through manual feed, but when i try to print from the tray it's stopped making the grinding noise, it just doesn't pick up the paper.
    I realized I mis-read the little screen it wasn't paper jam 01 it was Paper Jam 0] (zero and then a close bracket).
    Sorry for being a ludite- but what's an ADF?
  • volunteernab Dec 10, 2008
    We tapped away and no cigar.
    We might have to call in a service technician at this point.
    Is there anything else I can do aiside from cleaning,tapping, taking out trays and toner and looking for misplaced bits?
    Thannks.
  • Samsung Master
  • 4,806 Answers
I think that the paper feed cog/grab mechanism is broken, but you can try this>>>>>>>>> remove power from the printer, go to the PC and unistall the software, reboot the pc and power up the printer (leave the USB cable out) reinstall the printers software and connect the USB realign the cartridges and hopefully you will be able to print a test page.
If the printer still doesn't grab the paper your looking at a new one
kind regards
Posted on Dec 09, 2008
  • Lee Hodgson
    Lee Hodgson Dec 10, 2008
    you have tried all troubleshooting possibilities with regards to sorting the problem yourself and you are now out of options.
    You will probably have no choice but call a service technician now
    If it was a home printer you could have replaced it cheaply but because its an office printer a technician is required
    kind regards
    Sergeant:
  • 399 Answers
The gears which pulls the paper are misallighned and now able to pick up the paper. ------------------------------ or the gears r being blocked due to any dust thaT U said u tried cleaning. -------------------------------------- or it could also happen if the gears are slightly cracked in between so they r not able to spin fluently as they should be. ------------------------------------------------ or the paper pick up sensor is not working or moved from its orignal position,tap the printer up side down and also tap from all its sides. do it carefully and slowly.or call a tech nician at your place to get the new gear assembly fitted.
  • 734 Answers
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
  • futureloginn
    futureloginn Dec 10, 2008
  • 107 Answers
Sounds like you have a small bit a paper jammed in the gears, or the gears themself are jammed
  • 2 more comments
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    Input Misfeed
    1 Remove the remaining documents from the ADF.
    2 Open the ADF cover.
    3 Rotate the bushing on one end of the ADF roller toward the
    ADF ( ) and remove the roller from the slot( ). Pull the
    document gently to the right and out of the ADF.
    4 Close the ADF cover. Then load the documents back into
    the ADF
  • Eric Mitchell
    Paper Jam 1 In the fuser area or around
    the toner cartridge.
    In the Bypass tray
  • Eric Mitchell
    So check around that area and see in and little balls of paper or scraps of torn paper are stuck in there
  • Eric Mitchell
    javascript:openreq(http://downloadcenter.samsung.com/conten...')
    Page 119 shows you how to do it and 121 Ithink has the code list
My samsung printer scx-4521f show message: paper jam 01
Dear
Paper jam 1 caused du to the photo interupture and the lever connected at SMPS. Check the lever and sensor.
Thanks.
Jul 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F SOME TIME PAPER JAM
pls. send which error message shows in your display , while the paper jam occur.
solution depends up on that error message.
Apr 04, 2014 | Samsung SCX 4521F All-In-One Laser Printer
ON Samsung SCX 4216 Error: Paper Jam 0 Open/Close Door Can't find any paper stuck in it. Error does not go away even when turned off and on or unplugged.
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow" by compressed air.
more over roll the toner gear check if its not obstructing to something .
secondly try to cut/delete any pending print jobs thats right next to clock on your dektop.then restart PC and then plug the printer and PC on see if it works.
If still problem exist then, post your query here ,
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
Apr 05, 2011 | Samsung SCX-4216F All-In-One Laser Printer
My Samsung scx 4x20 printer shows paper jam in the dsisplay but there is NO paper jam. Can not get the error away and the printer refuses to print. What to do?
I suppose that the exit paper sensor in fusing section is broken (ussually when you pull out paper jam you can brake this little black or blue pawl). You can order and buy only this paper sensor pawl (very cheep).
pifonski
Feb 23, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam 2 displays however there is no paper jammed in the machine
This is caused by exit sensor or the problem may be a small peice of paper is still remaining. Or if its software error which will be cleared from service center. Please approach them.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4216F feed wheel
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
214 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
