Question about HP Pavilion zd8000 Notebook
Computer losing time HP zd8000 Laptop
The time and date no longer stay current. Can reset but it will not stay current. Could it be a weak CMOS battery? How do I cange it out?
    Problem Solver:
  • 6 Answers
Just open the case, pop the battery out and go buy a replacment. It's not hard to remove/replace it and you should see it pretty easily.
Posted on Dec 09, 2008
Reset cmos bios
Some laptop BIOS can be restored to the factory defaults in the BIOS setting - Default setting.
If your BIOS does not have this option then remove the BIOS battery for 20 or more mins. When you replace the BIOS battery the BIOS will be RESET then go into the BIOS setting scroll to Date & Time to set the current date and time.
May 23, 2013 | HP EliteBook 6930p Notebook PC
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
Tip
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
on Jan 12, 2011 | Microsoft Windows XP Professional
Am having hp g6 laptop and i forgot my password,so how can reset my password
Holy Cow a bios password?
Did you try removing the CMOS Battery?
You'll have to remove the CMOS battery. Most laptops require you to take the laptop apart to get to the CMOS Battery. It will be a silver battery about the of a nickel on the motherboard. The most common is CR2032. Also sometimes the battery will be in a vinyl covering and have a cable that attaches to a port on the motherboard. Whichever type you have you'll need to either remove the battery or unplug the cable and let the laptop sit for an hour or two. Then put it back, reassemble the laptop and reboot the laptop. With the CMOS battery out the computer will lose the date, time and password.
If removing the cmos batter does not remove the password you'll have to go to the manufacturers website and look for the manuals. See if the manual references how to reset bios. Most likely you'll have to short the jumpers or pull a pin.
Apr 02, 2012 | Computers & Internet
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
I have 2 x Dell older computers - sx620 from memory, 1 has reverted back to august 2005 every time it is turned off for about 12 months now, the second has started doing exactly the same thing for the...
It sounds like the CMOS battery(s) are dead. They hold the most recent boot information including current date. Assuming both machines are on the older side, it's entirely possible the CMOS batteries no longer are providing enough power to retain this information.
Feb 28, 2011 | Dell Computers & Internet
My date has to be reset every time I turn on my computer. How do I ensure the date and time is memorised thereby avoiding resetting. Thank you.
most of the cases the main reason behind the date time reset problem occurs due to weak CMOS battery on the motherboard. So, you just need to change your CMOS battery on your motherboard to resolve this problem.
Mar 29, 2010 | Computers & Internet
The time always changes whenever I turn the computer off. How do I get it to stay current?
Sounds like your CMOS battery is dead on your system. The is the Real Time Clock battery or RTC (CMOS). Your system needs to be opened, if it is a desktop, open the case and look for a disc shaped battery, remove and replace with the appropriate one. You will then have to get into the systems bios by tapping F2 wgen the computer starts and resetting the time and date, then once windows boots, you will have to reset the time and date in windows, time zone etc. If you have a laptop, you will have to find the type of battery that is installed and do the same procedure when installed.
Jan 05, 2010 | Computers & Internet
How to solve CMOS checksum and timer errors?
Your backup battery is to weak to save the cmos data. Open your computer case and look for a round silver battery that looks like a quarter. Remove it and go to Radio Shack or a drug store battery section and get a replacement. The battery number is probably CR2032 but may be CR2025 or CR2016. insert the new battery and power up your computer, this time when you set the time and date the settings will stay when you turn it off.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | Intel D945GCZ Motherboard
Not keeping time
Go into the BIOS by pressing F2 when you first turn on the laptop. In the main screen you should be able to change the time and date. After you do that save the changes and exit and go into windows and see if the date and time is current.
Let me know how it goes.
May 12, 2009 | HP Compaq Presario S3040SE (DF222AR#ABA)...
HP Pavilion zd8000 Notebook Logo
290 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
