Question about Nikon D40x Digital Camera
The Flash on my Nikon D40X will not operate
My D40X auto focuses, the flash pops up, but the flash doesn't go off. i get an "Info" alert that it is too dark to use my flash. Any suggestions?
  • 3 more comments
  • Anonymous Dec 17, 2008
    Yeah... I have the same problem sadly. Nikon support said I have to send it, they will evaulate it, but most likely I have a damaged flashboard... Which angers me, since I just got this camera today... with no coverage...
    But I will get back to you, because tomorrow I am having a CEO of a photography place look at my camera (My teachers good friend) and hopefully it won't come down to that... Or the person on ebay will get an ear-full...
  • radum40x Dec 24, 2008
    Same here... The built-in flash pops up but simply doesn't light up. Have no idea if the bulb is gone or there is some more serious damage. The camera auto focuses fine otherwise. Pls. suggest what should I try...
    Thanks
    RM
  • Anonymous Dec 27, 2008
    my d40x flash is failing. pops up but doesn't fire. rarely the flash does fire but waaaaaay too bright, or there is a timing problem that makes the whole image white. mostly it just doesn't fire. seems there is a physical problem.
  • Jesse Sidhu Dec 28, 2008
    • built-in flash pops up but the shutter speed will adjust itself to 1/60 sec. the flash will not fire either
  • carnesj Jan 03, 2009
    I have the same problem...I've had it for 1 year and 3 months...it just happened on Dec 31st...the last picture I took that the flash work was on 12/26/2008...
  • 176 Answers
Sounds like flash board is bad, Needs to fix by a repair shop.TC
Posted on Dec 10, 2008
I have a Nikon D40X. The built in flash pops up but the flash does not go off (light up)....not aware of the capability of turning it off manually.
You have 2 options to try before you consider a service tech to look @ the camera.
Prelim : Ensure the batteries are charged & your using standard batteries.
Option 1 : Put the dial in Auto mode and see if that helps with the flash, also ensure you are trying to click the picture in a dim or dark environment, else the Auto flash won't fire if the environment is bright enough
Option 2 : Backup your pictures and reset your camera by using the menu. This should take care of any settings that might have been accidentally turned ON or OFF, then try to get back to the option 1 to see if the flash fires... (you will have to set the date & time post this action)
Mar 30, 2011 | Nikon D40x Digital Camera
Flash on my Nikon D40x digital camers not working.
First look at you mode dial on the camera and make sure it is not on the setting with a picture of a flash with a cross through it. If that doesn't work in your menu see if the flash is disabled. Note: When On A Manual Mode You Need To Manually Pop Up The Flash
Oct 24, 2010 | Nikon D40x Digital Camera
Nikon d40x cannot force flash on auto mode
That is correct. Auto mode is exactly what the name says. The camera automatically decides whether to use the flash or not.
If you need to use the flash, switch to one of the non-auto exposure modes, such as P.
Jul 12, 2010 | Nikon D40x Digital Camera
Nikon D40x flash will not go off
I have the D40x. Only thing i can think of is the little sensor thing on the front down and to the left of the release button. If you have your finger over it, the flash don't work and the focus won't work right. "Infrared assist" in the manual. Myself, I use the sb400 strobe flash cause the popup flash uses too much power from the camera battery.
Jun 28, 2009 | Nikon COOLPIX L3 Digital Camera
Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Mar 31, 2009 | Nikon D40x Digital Camera
Flash not automatically opening up.
Check the flash setting in the shooting mode (on Auto). Press the "?" button twice. You should see the flash mode window. Small box on the lower left for flash settings (hi-lighted in yellow, or navigate to it). Press OK to see and change flash settings to your preference.
Apr 18, 2008 | Nikon D40x Digital Camera
Focusing
Best way to take macro in DSLR is try A/V mode and switch aperture F value to small value.if you don't have enough light macro need your flash sync.
Dec 06, 2007 | Nikon D40x Digital Camera
May I use a Soligor 24D Flash on my new Nikon D40X Digital Camera
You can purchase an off-camera flash sync adaptor at any good camera store, complete with extension cable.   The should work fine.
Nov 28, 2007 | Nikon D40x Digital Camera
Nikon D40X inbuilt flash
If it's withing 30 days, get it exchanged. I have a D70s and it's been working fine for me, maybe something with the D40x with other customers? Take it back to the store and let an "instructor" try it out to make sure it's not a setting.
It's great for the manufacturer to know about any problems so they can get a good sample of problems to help many people. Good luck.
Nov 16, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
116 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
