Question about Video Game Consoles & Games
The unit doesn't charge or either orange light is not lighted
While playing the GBA SP with red light on and charging at the same time it suddenly shutdown and when swithched on again, shutdown again and again.Is the battery depleted or drained?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
You probably need to get a new battery. After a certaint amount of usage, the battery loses it's charging capacity.
Try buying a new one at http://www.calcellular.com/ntd-ba-sp.html
Posted on Dec 29, 2008
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
My GBA SP wont charge
The lead or plug on your charger may be cracked. I have a SP charger but it has a bit of the plastic cracked off and has to be in a certain position to work properly. Otherwise you will need a new battery.
Jun 16, 2010 | Nintendo Game Boy Advance Console
Gameboy not charging
Sounds like the cells inside of the battery are weak and can't hold the charge. If possible, try a known good working battery and then charge it up. If the charge holds and you can run the battery off of it for a while then you know the original battery is bad.
If you try a known good battery and the charge still doesn't hold then it could be the main board inside of the GBA is bad and you would need to get another system unless the one you have happens to still be under warranty.
You can also try a know good ac adapter at that point as well to make sure your adapter isnt flaky but if you can turn on your gba with just the adapter hooked up then more then likely the adapter is good.
Jun 27, 2009 | Nintendo Game Boy Advance SP Console
Gba sp doesn't charge
maybe there is something wrong with the gba
Dec 06, 2008 | Video Game Consoles & Games
GBA SP not turning on
Did you charge it overnight? The battery was probably too dead for it to turn on. Or, your charger or battery may be bad. Try using another charger and if that doesn't work, replace the battery.
Nov 26, 2008 | Nintendo Game Boy Advance SP Console
Video Game Consoles & Games Logo
127 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
