Question about Ruud Handler Air Conditioner
Fan blower overheating
I have had a RUUD UBHC-21J18SFA air handler for 4 years. The fan runs for a while and then stops and there is a burnt smell. If I let it cool down for a while, it will start again and do the same thing about 30 minutes later. I checked the filters, they are O.K. No major dust accumulation in the unit. I noticed the blower wheel (squirrel cage) has a slight vibration laterally when it spins, sort of off balance, but nothing major, it doesn't rub on either side. The motor becomes very hot to touch while running. I can turn the fan with my fingers when the power is off, and with a slight swing, it will spin for approximately 3/4 of a turn. Somebody told me it should turn 4-5 times around with a manual spin before stopping... I took out the cage and the motor and can turn the motor shaft manually but it seems a little sticky.
Is the problem the motor? or the capacitor? Or is the slightly off balance cage causing the motor to overheat?
Any diagnostic tests I can do myself to find the SOURCE of the problem?
Thanks!
  • bedardjp Dec 11, 2008
    The motor is bad. The shaft was a little loose and the "bushings" (bearings?) were damaged. I called the dealer and there is no more garantee on the motor because it was installed 5 1/2 years ago though I have owned the house (and the air handler for only 4 years). He is asking over 500$ to order the original GE 1/3 hp 900 rpm 3.2 amps motor. The motor is supposed to be a sealed "no maintenance" model but I was told I could lubricate the "bushings" with a little mechanical oil once in a while as preventive maintenance so this doesn't happen again..
    Question 1: Can I save this motor if I open it? Any parts I can change or lubricate inside to make it turn smooth again like tuning up a bicycle wheel?
    Question 2: If have called everywhere and I don't seem to find a replacement model (besides ordering the 500$ original from the dealer!!!) for the original motor. Either the specifications don't match or they don't have the 8 screw holes for mounting. I found a 1/3 hp with only 825 rpm max or a 1/2 hp with 1075 rpm max. Can I take a chance with either one or am I "doomed" to pay big bucks and order from the manufacturer.
    Thanks for your time.
    I'm in Montreal, Canada. Internet companies in the USA don't seem to ship to Canada. I got the bushings changed on the original motor as an emergency solution. It's been running for the last 12 hours . Hope it will last a while. I also purchased the stronger 1/2 HP 1075 max rpm motor at a more reasonable price. The guy told me if it turned too fast, I could «gear down» by choosing t0o connect a different wire (high or medium or low). With a little fitting I hope it will work when the other motor goes down for good.
    Thanks again for your time.
  • 96 Answers
There are other motors out there that will fit what area do yo live because someone should have one or go on the net and try USA Manufacturing out of Lebenon IN. or let me know
Posted on Dec 11, 2008
  • 96 Answers
Sounds like your motor is bad check when it was installed all the units have a 5 yr warranty on parts but a HVAC contractor has to change it for the warranty
Posted on Dec 09, 2008
  • dwkcool Dec 11, 2008
    Good luck and yes you can slow it down
It appears that I have a bad blower motor on a ruud ubhc- 14 J 06 NFH.. how do you remove the blower motor housing from the air handler
inside blower housing you have 4 bolts attaching squirrel cage housing to upper track. remove it comes out with motor attached.
May 26, 2015 | Ruud Heating & Cooling
Ruud model ubhc 21j18shg
Sounds like the transformer blew. Check low voltage to see if you have 24Volts
Dec 13, 2013 | Ruud UBHC Air Conditioner
I have a Ruud heat pump/air conditioner. The out side fan and unit works fine and cools fine but now the inside fan that blows the cool air in will not turn on. We can turn the fan with our hand so I don't...
You didn't mention if you checked for 115 volts at the power supply to the air handler. The unit outside has its own power supply. A lot of times the switch that is on the wall doesn't like to work after its been turned off and back on for service, also check the blower door safety switch. If the blower door hasn't been put back in place properly and snugly it will kill power to the whole air handler. Hope this helps. Good luck
Jul 31, 2013 | Ruud UBHC Air Conditioner
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
When i tunn on my AC unit at the thermostat it blows the 3 amp fuse in the air handler when it call for cool when i switch the t stat to off and just turn fan on the fuse does not blow and blower runs
sounds like the compressor is or a electrical component directly linked with the cooling operation/ outdoor unit running.
Possible short to earth....
cheers
Jul 05, 2010 | Ruud UBHC Air Conditioner
Air handler motor stopped working
Check the capacitor before you replace the motor. It's a common problem that's easily fixed. Make sure the fan rotates freely.
May 23, 2010 | Ruud UBHC Air Conditioner
Ruud UBHC-21J18SFA blowing only "luke warm" air at best
That's crazy, we're having the same problem.  Turns out there was a wattage restrictor in the furnace that was switching off 3 of the 5 heating elements in an attempt to save energy.  Basically, the restrictor was sensing that the incoming air was warm, so only 2 of the 5 coils should be needed to heat the air.  Well that wasn't enough and we just sat with the furnace running all day long struggling to reach the 70 degree setpoint.
This is something a technician can diagnose in a few minutes, but not the sort of thing a DIY'er should really handle.
Dec 22, 2008 | Ruud UBHC Air Conditioner
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
317 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
