Question about HP LaserJet 3330MFP All-In-One Printer
Coppier Problem My HP laserjet 3330 display showed: "Scanner bulb warming up" then switched to " Scanner Error. Power on, power off". The machine is completly un-operatable. I tried to turn power on and off for many days now it's still doesn't work. Please help me to solve this problem or tell me where I can have it fix. Thank you
    Problem Solver:
  • 12 Answers
The trouble is that the scanner assembly can't find its "home" station. Here is the most common solution. There is a reflective white stipe under the scanner glass that the scanner looks for. If the stripe is dirty, or if the scanner mirrors are dirty, the scanner won't sense its location, and cause a "scanner error". A qualified technician should be able to clean the assembly. The other option is to replace the scanner assembly. I hope this helps.
Posted on Feb 28, 2007
  • 5 Answers
If you're a visual learner this is the video for you (and me! It worked). Here's how to clean the mirrors if it's a scanner problem ie if the scanner seems to be 'stuck' & doesn't respond to being reset
https://www.youtube.com/watch?v=lqG_nmi3vC4
Posted on Jan 24, 2015
Hi! I cleaned the mirrors, but the machine dont do anything :S just say's scanner lamp heating on.
Posted on Sep 10, 2008
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
Cant print. says printer is offline, printer says scanner bulb is warmimg up. im using a mac
Your issue is caused by dust in the scanner optics. Here is a link to a web page with instructions on cleaning the optics and clearing the error.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 21, 2011 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Scanner error 52 during opening scanner bulb warming up error scanner error 52 what should i do
If you can open it, please reseat the scanner flex cable after turning the machine off. For full details on how to troubleshoot, please refer here.. Hp error code 50 - 59 Good luck. Thanks for using FixYa.
Jun 05, 2010 | HP LaserJet 3330 All-In-One Printer
My 3330 says scanner bulb is warming up then it gives me a error 79 message no ,matter how many times i restart it
The error 79 on that machine means that the scanner assembly has failed to align/calibrate. Could be due to a bad calibration strip on the scanner glass, have you ever sprayed glass cleaner directly onto the scanner glass? If so this can stain the calibration strip and render the scanner useless. It is probably best to have the machine serviced by HP.
Feb 05, 2010 | HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 MFP
I have that oranage triangle light blinking as warm up message continues I also had power loss I have taken the plug out and will wait a while and try again. I still get now scanner errors using ubuntu..
May 16, 2009 | HP LaserJet 3330 All-In-One Printer
Not working properly
I'm having a similar problem. So far my solution has been to disconnect the 3330 from power for a longer period (> 30min.) and then switch it back on again. After the self-test everything appears to be ok again. I've got no idea why, but this seems to work (for now)
May 07, 2008 | HP LaserJet 3330 All-In-One Printer
HP LASER JET 3330
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Apr 05, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330MFP All-In-One Printer Logo
453 people viewed this question
Clive
Clive
