Question about Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro tuning on/off
Do I need to keep my Saeco Odea Giro machine on all the times except for cleaning or turn it off each night and turn on in the morning?
    Genius:
  • 1,199 Answers
Turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Posted on Dec 09, 2008
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
Why won't my Saeco Odea Giro descale?
Might need some urn cleaner to do a proper job. Scale is dry chemicals that you want remove so use the proper cleaning agent.
Aug 09, 2014 | Saeco Odea Giro Espresso Maker -...
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
My Saeco Odea Giro has the element light permanently on (not flashing) and the strength light is set to 3, I cannot change it. I have tried descaling, cleaning etc. Any ideas?
The element light is saying it,s time to descale. Since you have done that you can remove it by holding down the water button for a few seconds until it goes off.The strenght light?.checked whether it is not sticking.
Dec 15, 2009 | Saeco Odea Giro Plus Coffee Maker
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Odea giro plus gear that drives the brew group has broken 3 times
The coffee is being ground too fine usually. Also not cleaning the brew group and lubricating it regularly can cause this.
The gears are standard plastic and any excessive force will cause them to break. The only things that cause excessive force to gears on saeco machines is fine coffee compacting in the brew group and/or a dirty brew group that gets stuck and does not cycle properly.
Mar 01, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
315 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
