Question about Bose Wave Radio
Reception for bose radio with cd player built-in antenna
($500.00 unit) comes in much better when your hand is close to set, tried it in differant rooms etc. with no solution to the problum. set is 8 yrs. old but problum has only been this year.
  • 20 Answers
Reception issue, happens with alot of old radios. Try a different aerial.
Posted on Dec 11, 2008
Have a bose wave and live in a metal building. Can't get hardly any am fm radio recept. 3.5 mm antena jack. Can I get an am fm antenna? And do I need to mount antenna outside?
The Bose has the option for external antenna, but uses the AC cord as the antenna, so first try stretching your AC cord to its fullest extent in a straight line, then in different directions to see if that improves the situation. This is for FM only. The AM uses an internal ferrite rod antenna, and this is sensitive to direction, so try rotating the radio in different directions to see if signal improves on AM, and place unit as near a window as possible.
If none of this helps, you will be able to use an external antenna, and no it is not mandatory that they be mounted outside ... as long as you have room indoors. In fact, several manufacturers market indoor antennas for apartment dwellers and others under restrictions against mounting antennas outdoors.
But, logically, the best way to improve reception is the largest antenna mounted as high up and as far away from obstructions between the antenna and transmitter as possible.
Good luck.
Don Miller, CET
CET Services
Bose Wave Radio Repairs
don.miller60@outllook.com
Apr 30, 2016 | Bose Audio Players & Recorders
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
Antena for bose radio?
The Bose uses its power cord as an FM antenna. Make sure it's reasonably stretched out (not coiled), and is not in surroundings that shield it from the outside (a steel frame building, though even here putting it close to a window can give you reception). If this isn't enough to get stations clearly, there is a jack on the back of the radio where you can plug in a dipole (piece of wire) antenna available from Bose -- not cheap for what it is -- an indoor antenna from Radio Shack or a similar store, or even a roof-mounted unit. If you don't buy from Bose, you'll need an adapter to convert from the standard plug everyone else uses to the phone jack Bose has decided to use instead. Radio Shack sells one: catalog 278-257.
Jul 13, 2014 | Bose Wave Radio
FM radio reception is poor. User manual suggests connecting an external antenna. Where do I connect it?
Hi, I think your units model number is AJ6111. According to the owners manual, the FM antenna is integrated to AC Power Cord. So you can not add antenna. But you can try to re arrange the cord and perhaps add an extension cord to see if reception gets better.
If this is not the unit you have, please try to provide the model number so I can look up the right owners manual and try to help you.
Good luck.
Mar 21, 2011 | Philips Under-Cabinet Alarm Clock Radio...
I have a bose wave radio fo many years, when turn it on there is a constant buzz as the radio plays. the buzz varies if i move or position the radio differently. sounds antenna related but there is no...
The antenna is built in. The buzz you're hearing is a 60cycle hum (electricity from a nearby appliance) Try this, put an extension cord on it and walk it around your listening room for best reception. You can also find the culprit appliance by turning items off 1 by 1 until buzz subsides.
Jan 04, 2011 | Bose Wave Radio
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Jun 17, 2009 | Bose Wave Radio
GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Oct 26, 2007 | GE 7-5295 Undercounter DC /Radio Combo -...
Am antennas
Hi, to all. There are currently two types of Bose Wave Radio system available in the market. The first one being the WRCD with the top loading CD mechanism. This unit does come with the Antennae cable inside the box and this should sort out your problem. Another option is using an outdoor aerial antennae and connect this to the antennae port behind the unit. The second one is the new Wave Music System with the front loading tray mechanism. This system uses a unique concept of using the electrical cable included in the box and utilise your electrical pwoer line as the antennae receptor. I recommedn to keeping the pwoer calbe fully extended. Another solution for this is that Bose service centers do have a specific spare parts calbe called the AM/FM antennae cable for WMS which you can simply buy for around 20$ I assume. this basically bypases the power calbe and routes antennae reception through this minicable (brownish colored RJ calbe).
Glad to be of service...
Oct 14, 2007 | Bose Wave Radio
Bose Wave Radio Logo
188 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
