Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
My print comes out blue.
When I print it comes out blue. So I deep clean the printer and ran the calibrate sheet. There was no yellow and only one black. I scan the calibrate sheet and reran still one black and no yellow.
    Problem Solver:
  • 15 Answers
I think it may be a faulty printhead. Phone or email Kodak, email printheaditg@kodak.com or phone 1-800-421-6699. option 1.
If its a bad printhead Kodak will send you a free one by overnight air. will also send you a free black and color ink ,cannot beat that.
Posted on Dec 12, 2008
Hi Ihave a MP-500 that prints off color.
You need a new printhead, QY6-0059-000, around $60.00. They do wear out and also plug when you use generic inks.
Oct 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Kodak 5300 prints light or not at all color does better
to resolve the problem try to clean the printhead first, to clean the printhead just press on the menu button, select clean printhead, select deep clean.
After you clean the printhead try to re-calibrate the printhead, just go back to the menu the select calibrate printer then select print calibration page. Once you have the calibration sheet, place it on top of the scanner make sure that the blue arrow on the printout is pointing on the yellow arrow located on the top corner of the scanner glass then press on the start button to scan the calibration page. Once the calibration is complete try to make a test print, just go back to the menu then select print demosheet then press ok. If this will not correct the problem you need to call their technical support hotline
Aug 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Calibration not working
When you place the calibration sheet on the scanner glass, make sure you put it with the blue arrow facing the yellow triangle on the scanner. (the page must be, obviously, facing down).
As with the red color issue goes, try replacing the color ink cartridge. If that does not work, contact kodak support to fix the problem (you can go to kodak.com/go/itg for troubleshooting steps)
Dec 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prints come out blue.
You may have a faulty printhead. I just purchased a new one and had a time with it. Awful color in picture. Kodak sent me a new printhead and new ink tanks. Now it works great. You may have printhead trouble also, contact Kodak for help.
Dec 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
Sep 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Color is all wrong
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
Sep 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 printer
K...Trust the solution. Try these steps. Open the printer, remove the ink and remove the printhead (See User's guide). Reseat the printhead and the ink cartridges. The printer will come up with an error message that requires calibration. Do the calibration and scan the sheet that prints right after by pushing the start button. In the menu options, clean the printhead. Do one basic and one deep. Print a demo sheet (another menu option) to see if the quality has gotten better. If it has not call Kodak AiO Tech support. You will need a replacement printhead.
Apr 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
80 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
