Question about Nokia 6120
Water damaged 6120
Good day bogdan,i am desperately seeking your help to revive my 6120classic.its brand new from the box(1week), i damaged it last friday,i had a hangover and vommited all over it, i didnt realize what had happened till i woke up later in the day;by that time it was TOTALLY soaked. i removed the battery,memory card then disassembled.i cleared the vommit with diluted rubbing alcohol&a small soft paintbrush ,then i sprayed the circuit board with a circuit cleaner then placed it in the sunlight for about 2hours. i reassembled,n tried to power up repeatedly...got nothing. so i put the charger on,it took 5mins for the screen to brighten,displaying 'NOKIA'. i left it there for abt 2more minutes till it just switched 'off',then 'on'...i removed the charger n it stayed on for 6mins more,then it went dead...i left it for abt 2hours before i tried to get some more life from it, bt all that came on was the keypad's lights. what should i do next? im jerome
  • 4 Answers
Check the network section or power section or c.p.u section
Posted on Apr 01, 2010
Fork oil capacity for kuda 250cc 2011 model
Hi,John I'm sorry you didn't like the answer I gave you 2 days ago but I did hear on the grapevine that if you call +61-3-9791-8811 and say please they just might give you the answer you so desperately seek. Good luck and have a nice day.
Oct 04, 2016 | Motorcycles
My apple iPhone4 will not charge and the battery is dead....bought new cord to charge but still will not charge up! Help please.....
Hi June, You need to take it to a repair shop, i would say the Power port is damaged that's why it's not charging
Mar 28, 2014 | Apple iPhone Smartphone
Loss of power will not go over 2000 revs
Check wiring and connector for the no. 4 cylinder injector.
log on to kiausa.com
Very good site with guided fault seeking and all info you need.
Mar 25, 2014 | 2002 Kia Sedona
I have an Intex 18x48 easy set pool and pump is shutting off/tripping circuit breaker after running for 1 minute for last 2-3 days. I called Intex (after reading questions posted here) and they are...
Pour some bleach (about 2 gallons) around the perimeter and give it a good brushing. May have to repeat in a few days. That should hold fine.
Jun 26, 2013 | Pool & Spa
My yz250 two stroke has no spark in the plug and i put a brand new spark plug into it but still no spark or sign of life from the bike just kicking it over and over and its not starting could someone...
Hi, Chrislee4amy and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
NO SPARK Desperate for help will pay for solution General Dirt Bike...
Yamaha YZ250 Project Part 1 No Spark
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 19, 2011 | Yamaha YZ 250 Motorcycles
Showing no disk?
If it is still under warranty then target have to exchange or give money back if faulty not sure what country you are in but consumer affairs should be able to assist you. The seller must honor their warranty period
Apr 26, 2010 | RCA DRC629N Portable DVD Player
LG Vue touch screen doesn't work anymore
I had this problem last week. Though I have had mine for over a year. It is not a fixable problem. I hope you included insurance with your phone purchase because I was told it most definitely needed to be replaced. I got my new one, they sent it overnight delivery.
It was so frustrating not being able to see my texts and dial a phone number that was not in my call logs.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
What tv to buy
wouldn't buy a vizio if my life depended on it. Check out good name brands such as Sony, Panasonic, Hitachi, and Mitsubishi. no matter what you get its going to brake. I would recommend a 5year extended warranty with any new set you get these days. Also get LCD not plasma!
Let me know if you have more questions or if you have a certain model number you are looking at. With your price point in minde you most likley will need to look at a 42" in these brands. Dont think you will get anything bigger than that. Let me know!
Tim Nolan
Sep 19, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Wet phone
Unfortunately you phone has water damage, and your warrenty does not cover that. For your information, either behind the battery, or within the casing, there is a white dot, and when the white dot turns red the service provider knows that your phone has been in contact with water. Your two options are to buy a new phone, or to wait it out and hopefully your phone will air dry and everything will work ok.
Sep 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 6120 Logo
112 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
