Question about Microsoft Xbox 360 Console
Xbox 360 turns on somtimes plzz help 1 xbox 360 evr owned.
My xbox 360 wont turn on somtimes for example maybe after turning it off for 10 minutes it wont turn on or after a night of playing it wont turn on i think it might be the powerdord maybe i need a new one? i sent my xbox in befor all this started happening because i had the e74 error and now this is happening. also could this be happening if i unplug the power cord for the outlet when the xbox is turned on i had to unplug it when it was turned on like 5 times becasue my xbox360 wouldnt tunr off and i it wouldnt turn off because the faceplates power button broke of so i had no other way to turn it off.
  • 24 Answers
Hi well the problem is i think the wires to the block maybe loose or there maybe be a problem with the brick wiring inside maybe burn out
Posted on Mar 04, 2009
  • 154 Answers
Get connicetion from laptop to get online
  1. Turn off Xbox 360 console and network hardware (for example, your modem and router).Wait 30 seconds.
  2. Turn on your modem and wait a minute.Turn on the next piece of hardware (for example, your router) and wait another minute.Turn on your Xbox 360 console.On your console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or your wireless network if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.If Xbox LIVE performance is still slow, try the next solution.
Dec 29, 2010 | Microsoft Xbox 360 Console
E73 xbox
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Apr 02, 2010 | Microsoft Xbox 360 Console
How do i fix my xbox 360 e73??
The Sticks Method:
Feb 05, 2010 | Microsoft Xbox 360 Controller
My xbox wont work
The Xbox 360 will break from over heating itself. Maybe the rattling was the cooling system. Send the Xbox 360 to Microsoft and they will send you a new one free.(Save your hard drive!)
Jul 15, 2009 | Microsoft Xbox 360 Console
Turns on and works great...after about 10 minutes it doesnt work.
it is probably because your xbox is over heatng and you have a bad or loose wire in your xbox, try to put a fan facing the back of it before u turn it on
Jun 04, 2009 | Microsoft Xbox 360 Console
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
open the xbox and fix the faceplate yourself and try getting a new power cord or a new powerbrick
Dec 09, 2008 | Microsoft Xbox 360 Console
Xbox 360
Its probably getting heated up, so try putting it in a moreopen cooler area.
Jul 12, 2008 | Microsoft Xbox 360 Console
Xbox 360 Freeze!!
It's a common fault with X boxes, the red lights indicate overheating, so make sure it is well ventillated and if neccasary you can purchase an add on cooler for the system.
Dec 30, 2006 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
95 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
