Question about Krups ProAroma 453-42 Coffee Maker
Krups 453 - coffee is weak
I've had my Krups coffee maker for a couple years now and have been very pleased with it's performance and taste. However, just lately, the coffee has been non-flavorful and weak tasting. I have switched coffee brands assuming that this is the problem.....but no luck- coffee is still like hot water! I used the charcoal filter (that came with my unit) for only a short time (a couple months) then I never used one at all and continued to have great coffee for the last couple years. I've recently de-scaled the maker as well but this did not fix the problem. Any thoughts??
  • Krups Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
I need to replace my Krups 453 Thermo fuse (ms-0061607). Where can I find one or is there a replacement?
Many times the Thermal (not Thermo) fuse is soldered in line with silver solder and unless you have the ability to cut the old one out and replace it, the cost would be greater than a replacement coffee maker.
Jan 05, 2015 | Krups ProAroma 453-71 Coffee Maker
Our Krups heats the water but does not brew
may be its not heating properly try some descaleing
Jul 13, 2014 | Krups ProAroma 453-71 Coffee Maker
I need a manual for a Krups Pro Aroma 453-42 12-Cup Coffee Maker
Hello, fran
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Aug 30, 2011 | Krups ProAroma 453-42 Coffee Maker
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
The coffeemaker tube leaks on my Krups ProAroma 452. How do I replace the tube?
I have the same problem. The rubber elbow seems to have shrunk with aging. Krups customer service pointed my to SmallAppliance.com for a replacement part. It appears that "Krups 0067516 Coffeemaker Tube" is the proper replacement. It is a special order part that may take 6 weeks to ship. The elbow pulled off a connection inside the coffee maker and I hope that the replacement will just slip back on. While I haven't completed the repair, I think I'm on the right path.
Jun 17, 2010 | Krups ProAroma 453-42 Coffee Maker
I lost my user manual for a Krups ProAroma453-71 coffee maker. Where can I find one?
Contact Krups, and they should be able to send you out a new one. Their phone number (according to their website, www.krupsusa.com ) is 1-800-526-5377
Good luck! :)
Aug 26, 2009 | Krups ProAroma 453-71 Coffee Maker
How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Jun 05, 2009 | Krups ProAroma 453-71 Coffee Maker
Coffee weak
IT MIGHT NEED DESCALING RUN SOME WATER AND WHITE VINEGAR THEN RUN CLEAN WATER A COUPLE OF TIMES AND MAKE COFFEE SEE IF ANY BETTER PS WHITE & ONE SUGAR FOR ME THANKS HOPE THIS IS HELPFUL GLENN.............
Nov 15, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Krups ProAroma 453-42 Coffee Maker Logo
398 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
