Question about Philips GoGear HDD1850 MP3 Player
Can't Sync to mp3
I have my mp3 connceted to the computer, I hit the sync button but the computer screen says to conncet a device! What do i do??
  • deedee315 Feb 26, 2008
    when i connected my mp3 and press sync it keep saying connect a device and if i unplugged my mp3 all it say is connect to pc it do not come on at all. what should i do?
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
Controler not connceting it keeps say reconncet controller
You have to hit the sync button on the console and then hit the sync button on the controller.
Jan 28, 2014 | Microsoft Xbox 360 Console
Hello i am having problems setting my coby mp3 player to the vaio computer so that i can put song on the player i already have my playlist in order but when i press start sync nothing happens what should i...
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then following the following the instruction about loading it throuh Windows Media Player: Connect your MP3 player to the computer using the USB cord. Open the Windows Media Player program. When you open the program, your device will be recognized through the "Sync" button on the tool bar that runs across the top of the page. Click on the "Sync" button. To the right a column will appear which says "sync list" at the top. Below the sync list it will say "Drag items here to create sync list." Your library is located in the middle part of the screen. (Your playlists and library listings are in a column to the left.) To select the songs you wish to transfer, simply click on the song and literally drag it over to the listing on the right. When your mouse is over the column, the text will lighten, and a small box with a plus sign will appear. When this happens, let up off the mouse button. The new song will be listed in the sync list. When you have a listing of all the songs you wish to ad, click on the "Start sync" button near the bottom of the column. You will be taken to another screen which will have a listing of the songs you want to add. The computer will sync the songs to the device. When the synchronization is complete, the sync device column will return to the right of the screen. A message will appear letting you know that it is ok for you to disconnect your device. When you unplug the device, the MP3 player should flash a message that says, "Creating (or configuring) library."
Oct 01, 2009 | Coby MP-C582 MP3 Player
Ipod connceted thru usb to computer for charging - locked
i had the same the issue due to my ipod. the problem that i think is with you is that you may have done something. To get your ipod on again hook it to the computer (USB cord) and re format it. that means you would have to clean your drive completely.. dont worry!!! then you need to put songs all over again...
Aug 10, 2009 | Apple iPod nano
Mp3 player won't sync with media player on vista
Do you have Windows Media Player 11? When you plug your device in and hit sync you should be prompted automatically, to name your device.
Also try:
Plug in the device, press the POWER BUTTON go to MY COMPUTER and double ckick on the Setup.exe icon.
This will install the MP3 Player's software onto the connected computer. At least that's what the manual says.
http://s366.photobucket.com/albums/oo105/aStrangerInParadise/
Feb 24, 2009 | GPX ML648B MP3 Player
Computer doesn't recognize MP3 player -
Try to reboot your PC. Leave mp3 player off when start Sync (if button lights up this time).
Jan 20, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Formet
download itunes at apple.com.install then sync ipod with itunes.Itunes will reinstall a file needed by the ipod.
Was this solution helpful? Show your Appreciation by rating it.RICHARDM69
Dec 14, 2008 | Apple iPod nano
Don't transfer playlists - only transfer individual songs
Sep 15, 2008 | SanDisk Sansa Clip MP3 Player
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Jul 13, 2008 | SanDisk Sansa m240 MP3 Player
Can't Sync to mp3
how to get sync workin
Apr 20, 2008 | Audio Players & Recorders
Cant down load songs i like
Go into WMP and connect the USB cable to your computer and player. Press the M button on the side til the screen reads "MTP." The device set-up wizard should start. Then hit the "sync" menu and drag and drop songs onto your sync list
Dec 25, 2007 | GPX MW3837 MP3 Player
Philips GoGear HDD1850 MP3 Player Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
