Question about Hyundai ImageQuest L70N 17" LCD Monitor
19inch hyundai imagequest monitor problem, no screen picture
Any one help please, is it an easy sollution or cud it be many a problem with a dud screen ,on/off button ok but no picture or sound also wots the thin green jack/plug comming off the blue printer block connector, were does it go.thanks ,dully.
How can I reduce the brightness of the screen?
Posted on Jan 12, 2009
    Problem Solver:
  • 8 Answers
The first thing to check is the power supply to the monitor. Mine went a while ago, black screen nothing happening, turns out it was just the power supply. A quick search on your favourite browser will probably turn up a supplier, I found one that just makes monitor power supplies, so it must be a common problem!
If you have a meter test the power coming into the monitor, or if you're unsure put it to your ear when its plugged in, you should hear a faint buzz which means its working. Also check for any breaks in the cable and/or if there is a fuse in the plug which might have blown**
**If a fuse has blown, it might point to another problem, but at least it's a starting point
Posted on Dec 09, 2008
My Hyundai B70A's screen is blank grey. I've changed the power supply, the vga cord and the video card with no change. What should I do now?
If you get just the grey glowing screen (as shown in my guide), it means that the T-CON board on the LCD panel is not getting the 5 or 12vdc from the logic board or it has blown fuse on the T-CON board due to shorts circuits, not much you can do but replacing the LCD panel.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find.
Oct 15, 2010 | Hyundai ImageQuest ImageQuest B70A (Black,...
My hyundai imagequest l70n lcd monitor started to started to make a high pitched noise and the screen went black but the green light stayed on but now i plug it in and nothing happens no picture and no...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 12, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
I have pushed the screen down and i can't get it back up. Please help
Open the case of the monitor and reseat the lcd panel. Beware, it's very fragile and cannot be repaired.
Nov 25, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
Speaker in screen dosen't work
a normal minijack (3,5 mm) cable, with the same plug in both ends.
if you have a cable already, try to adjust the volume using the buttons on the screen
Mar 10, 2009 | Hyundai ImageQuest Q17 17" LCD Monitor
The regulator ic is lm7812 series lm no matter replace it or 12v regulator
Nov 26, 2008 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Hyundai imagequest B90D orange standby
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Nov 13, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Monitor Hyundai N91S
please reinstall your motherboard cd once again if not upgrade your graphics card...
Dec 31, 2007 | Hyundai Electronics ImageQuest N91S 19"...
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Hyundai ImageQuest L70N 17" LCD Monitor Logo
342 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
