Question about Kenmore 23822 Top Load Washer
Washer will not spin properly on a Kenmore 110 23812100
It goes through the cycle but when finished I pull open the lid, (top loader) and everything is sitting in some water and has not spun properly. I had to keep running through the spin cycle until it worked. Not sure why I have to keep repeating this cycle.
  • Anonymous Mar 29, 2014
    the washer locked up after the cycle finished and we couldn't get it open until we released the interior lever. Once we released that the washer will not run now.
  • 71 Answers
Your pump is partially clogged or your drain hose is kinked
Posted on Dec 12, 2008
My Kenmore 26442502 top load washer will not kick into the spin cycle after it agitates. Just kinda humms. As I open the lid while it should be spinnning, everything stops, like it should. Once I close the...
Hello Dbriner,
It would appear that the lid switch is defective and is in need of replacement. I included a video showing basically how to replace it (It is a series 80 machine but that is minor).The steps are the same.
Your part can be found here for $29.65 +Shipping
Good Luck!
Rich Lilja Kenmore Washing Machine Lid Switch Assembly WP8318084
May 20, 2017 | Kenmore 24032\24036 Top Load Washer
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
No rinse, no drain, no final spin
I assume this is a top loader, check the lid switch, you should hear it "click" when the lid is lifted. If no click the switch is broken.
Dec 20, 2009 | Kenmore Washing Machines
I have a kenmore top loader it will do everything except empty water and spin when it reaches this point nothing happens and there is no sound at all
Probably a bad lid switch. Open the control console and use a insulated jumper wire to jump out the lid switch connector and try the spin cycle. If it works, replace the lid switch.
If not, replace the timer.
May 15, 2009 | Admiral AW22 Top Load Washer
Kenmore 70 series top loader - wouldn't drain & spin
The lid switch is the only thing affecting this part of the cycle. The new switch comes with the new plug (under console ) and the harness that goes to the switch. The console will flip up and the cabinet will pull forward after removing 2 brass looking clips. After that it's right there under the right side of the upper cabinet.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 23822 Top Load Washer Logo
431 people viewed this question
Sal De
fordexpert
Robert Rankin
