Question about BSA Deerhunter Riflescopes Deerhntr 3-9x40 Dh39x40
Windage adjust correction
I have a 3-9x40 deerhunter riflescope, have a problem with the windage adjust, cand you send to me, manual for repair or peaces?
  • 75 Answers
Go to; for the manual and parts.
You do not say if the WINDAGE Adjustment KNOB is 'broken' or what? If you have dropped it or somehow broken it, it's unlikely that you will be able to repair it yourself, in which case I refer you again to BSA.
If there's nothing wrong with the scope or your rifle, and you are simply having difficulty getting a good ZERO, I can help you with that, just respond and let me know.
Good luck. :)
Posted on Apr 29, 2009
Windage and elevation adjustment won't move on konus 275 scope
you may have run out of clicks or the adjustment internals are damaged
Nov 02, 2013 | Konuspro 275 Muzzleloading Riflescope...
Cannot set wind age and elevation on a Nikon pro staff riflescope (not enough adjustment )
Check you mounts. If mounted properly you should have enough. if they are not moving at all you have prob broken the fine wires that form the crosshairs.
Jan 07, 2013 | Nikon 3-9x50 Prostaff Riflescope In Matte...
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
Hi, just bought a Hawke Varmint II 4-16x44 AO. I started searching for the zero point, before I mounted it on the rifle Itself. Because I wanted to make a bigger adjustments from the mounts when bore...
The Hawke comes with a good, lifetime warranty.
They are reported to be fast and fair about these things.
The best thing you can do is send it back and they will fix it or replace it.
Oct 30, 2010 | Hawke Sport Optics Hawke HK3232 Varmint II...
I have an older Bausch and Lomb scope and have lost one of the screw on covers for the windage adjustment. where can i find a replacement
I have seen covers in the Midway catalog and Brownells, both have replacement covers and turret knobs. Hope this helps.
May 12, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
Apr 04, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link:
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Windage fully clockwise "In" and not quite there at 100 yds.
remount the scope using millett angle lock rings that allow you to adjust for windage. bring the scope as close to hitting bulls eye as possible then use the scopes adjustments for the fine tuning. before remounting you will want to recenter the reticule.
Mar 14, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
New Zeiss 2.5-8 Conquest MC Riflescope. Elevation clickstop adjus
Tried google for zeiss rifle scopes I just did and see they have a suport division...try there and get it from the horsies mouth!!!
Jun 07, 2009 | Conquest Zeiss 3.5-10x50 Mc Rifle Scope :...
BSA Deerhunter Riflescopes Deerhntr 3-9x40 Dh39x40 Logo
414 people viewed this question
Top BSA Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a BSA Optic Expert? Answer questions, earn points and help others
