Question about Traeger Industries BBQ070 All-in-One Grill / Smoker
Grill takes a long time to heat up after staring ?
I cleaned the entire unit and refilled the pellet bin, but the tempature gage shows it takes over 1/2 hour before reachinhing 400 degrees.
Green mountain pellet grill doesn't heat up. Put a new igniter in it. Goes from 3 degrees to 85. The auger works and the combustion fan is running. Any idea
Have you cleaned out the burner area. Every so often (especially if you see a lot of ash flying around) you need to take the grills and other deflectors out and vacuum the burner area out. You may be full of ash.
Sep 17, 2017 | Grilling
What is the biggest problem with a pellet grill smoker? Is it not as quick as a gas or charcoal grill or is the food taste too dry?
I think pellet grill smokers are ideal for some barbeque tasks and not others. What the drawbacks of a pellet grillare will depend on what you are trying to do with it. I'm linking to an extremely detailed article which addresses the pros and cons of pellet grilling. Top 5 BBQ Grill Smokers Grill it Smoke it
Oct 21, 2016 | Grilling
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site FAQ
"My Unit Goes Out On Smoke
  1. Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
  2. If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
May 29, 2015 | Traeger Industries BBQ070 All-in-One Grill...
My treager heats but on high it will only get up to 150.
Hi, if you haven't already done so, I would recommend you remove the grate and heat plate to clean out the ash from the fire box. Accumulated ash will restrict airflow into the fire box preventing good combustion. While using genuine treager pellets and standard shut-down/cool-down cycle, I have to clean it out periodically.
Apr 20, 2014 | Traeger Industries BBQ070 All-in-One Grill...
2008 V6 3.9 pontiac montana still over heating
Hi, Yes you have an air lock in your system, you may get this sorted by 1/. Removing one of the cooling hoses & try to blow with air.
2/. Drain all the system then put your heater on inside the vehicle & have the engine running & refill the system Start to do this from a cold engine. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 27, 2017 | Pontiac Montana Cars & Trucks
I had my 2006 grand prix fix 3 times for the tempature gage and stilss the gage goes over the 3 line
I think you should start thinking it might not be the gage itself but >Problem with the wires in the circuit itself Also warm car up take a thermometer & check coolant tempature cross referance with temp gauge in the car
Jun 16, 2011 | 2006 Pontiac Grand Prix
I have a natural gas hookup and my grill takes a long time to heaat up (15 minutes) and max degrees is 350 - 375. I found dust in the connection hose blew ut out. Also took grill apart and cleaned...
Unfortunately, that's the way it does on Natural Gas, in an outdoor environment. The reason being, Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Of course, on the plus side, you don't have to get tanks refilled. With that said, the thermometer on the grill may be faulty.
To test this theory, buy an inexpensive oven thermometer (the kind that can be placed on an oven rack) and place inside the grill, when you're preheating it with the lid closed. Once you grill thermometer reaches 350 degrees, open the grill hood and compare it the two temperature readings. If the oven thermometer is reading significantly higher, then you no the grill thermometer is faulty.
Hope this helps you get back up to temperature.
Mar 02, 2011 | Weber SPIRIT E-210 (NG)
Pellets keep feeding. cant control temp.
Are you trying to grill or smoke? In ether case, once the pellets ignite and the temperature you want has been reached, the switch should be turned to off. That should stop the auger pellet feed.
Also, are you using Traeger Pellets. They are the only one designed for this grill/smoker. If you're using heating pellets for a pellet stove, that also would cause that problem
If you've lost your Owners Manual, here's a link to it in a downloadable and printable pdf format.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ070_Manual.pdf
Hope this helps. Please let me know.
Feb 06, 2011 | Traeger Industries BBQ070 All-in-One Grill...
2001 Alero- heat gage does not show heat tempature. Blows warm air.Engine felt cold after a 50 mile trip. Out side tempature 20 degrees fernaheight.
with winter being here you might want to consider having a new thermostat put in to increase the heat in side,but make sure your radiator is full when engine is cold
Dec 26, 2009 | 2002 Oldsmobile Alero
Traeger Industries BBQ070 All-in-One Grill / Smoker Logo
495 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
